Topic: Audio Trouble! Please help!
WoohtyHome userMember since 2017
So I've updated all the firmware and drivers for my controller and everything but when i pull the audio settings the DDJ-1000 is not under my hardware and I'm not able to put it on the Master for audio output.
Posted Mon 16 Sep 19 @ 7:15 pm
You need to check whether your computer OS is recognising the DDJ-1000. When you power it up & plug it in, does your computer (PC? Mac?) detect the audio interface?
If it doesn't then you should try the controller on another computer to see if the same thing happens.
Posted Mon 16 Sep 19 @ 7:35 pm
