Hello everyone,
I recently acquired a Pioneer SB3 controller that is native to Serato, I prefer Virtual Dj but I have a problem with it.
I own the infinity license in the latest version.
In terms of pitch tempo and gain buttons, I find that these settings do not react very well when I use it.
Several round trips are necessary to make them react!
On the other hand with Serato lite it does not do it but Serato makes my laptop bueugue.
Odd no?
If you had an idea ...
Thank you
Odd no?
Thank you
Posted Sun 15 Sep 19 @ 4:58 am
Maybe you just don't like the default takeover mode? Luckily they are adjustable in VDJ (Serato only has one, so nothing to do in that software)
If so maybe this will inspire you
Posted Sun 15 Sep 19 @ 4:12 pm
