Before the last update I could use the auto mix menu to change the length of the fade, the type , etc. now when I bring the menu up I can't see the extended options when I am hooked up to an external monitor. I use video all the time.Is there a fix in the future or a work around for this. I am on a MacBook .
Posted Thu 22 Aug 19 @ 9:21 pm
Yes, it's a known issue,
until it is fixed you can open info panel to let the menu appear
Posted Thu 22 Aug 19 @ 11:14 pm
This would have been good to know this past Saturday. Thanks!
Posted Fri 23 Aug 19 @ 12:10 am
As well in a way to modify info fields you may need to open an effect GUI
Posted Fri 23 Aug 19 @ 4:05 am
You also could have gone back to an earlier build.
Posted Fri 23 Aug 19 @ 2:44 pm
or open the playlist_options via script
or use Automix Live pad page
Posted Fri 23 Aug 19 @ 3:21 pm
Thanks For The Info guys. Greatly appreciated !!!
Posted Fri 23 Aug 19 @ 11:26 pm
locodog wrote :
left deck, make a custom button with the script
playlist_options
or
karaoke_options
or
sidelist_options
or open the info pane a bit
until it gets fixed
playlist_options
or
karaoke_options
or
sidelist_options
until it gets fixed
Posted Sat 24 Aug 19 @ 3:37 pm
