Topic: VST Effects don't work in the Master Slot
Since the latest Builds wenn I select a VST FX in the Master Slot Virtual DJ freeze .
In the Player FX Slots all working normal.
It is by all VSTs.
Please test it.
Thanks.
Greatings Dani
Posted Mon 19 Aug 19 @ 8:49 am
working in 5186 for me. i know that's no help.
Posted Mon 19 Aug 19 @ 9:11 am
By Me it freeze , but only in the Master Slot.
Posted Mon 19 Aug 19 @ 9:13 am
what vst? any or a specific?
Posted Mon 19 Aug 19 @ 9:22 am
All .
I have a lot from mine VSTs testet...
From UHE . Denise . BBE . Image Line . and many others.
When I select a VST , and open the GUI , than freeze and t new open..
Posted Mon 19 Aug 19 @ 9:45 am
AdionPRO InfinityCTOMember since 2006
Works fine here too.
32 or 64 bit? Happens with default skin?
Posted Mon 19 Aug 19 @ 11:08 am
32bit
Default Skin and others also.
Only by Master FX Slot.
Posted Mon 19 Aug 19 @ 11:17 am
Have anyone found this Error?
Posted Thu 29 Aug 19 @ 5:55 pm
What's your sound setup?
Also not working without any controller connected?
Posted Thu 29 Aug 19 @ 8:49 pm
My Soundsetup is NS6 Numark.
Bevor ever working fine.
The VSTs also workinking fine in the Playerslots , but in the Master FX Slot VDJ is freeze and I must start new ....
Posted Mon 02 Sep 19 @ 6:04 pm
The error is also in the new 2020.
Cant work with VST effects in the Master Slot.
Posted Fri 27 Sep 19 @ 3:36 pm
