I want to use this but I also want to make it so it uses a set of fxs different then the 3 I have already set.
Iโm sure itโs something to do with the XML but Iโm not sure what I need to change??
Phantom/George can you help me out please?
Posted Sat 17 Aug 19 @ 1:50 pm
So fx toggle/while_pressed with no effect slot?
Pad 1
Name : Add the fx name you want
Action : effect_active "yourFX"
Color : effect_active "yourFX" on ? var_equal 'FX1MomPush' 0 ? color 'green' : color 'blue' : color 'blue'
Pad 5
Action : effect_active "yourFX" on while_pressed & set 'FX1MomPush' 1 while_pressed
Color : effect_active "yourFX" on ? var_equal 'FX1MomPush' 1 ? color 'green' : color 'blue' : color 'blue'
Pad 1
Pad 5
Posted Sat 17 Aug 19 @ 2:06 pm
Awesome!!
Definitely gonna make working with the RX better in my opinion.
And Thanks ๐๐พ
And Thanks ๐๐พ
Posted Sat 17 Aug 19 @ 2:13 pm
Also since you don't need effect_select you have the shift pads free for 4 more fx.
Posted Sat 17 Aug 19 @ 2:25 pm
Oh man, I forgot all about that!!
Thinking cap back on ๐ค
Posted Sat 17 Aug 19 @ 2:58 pm
