About VirtualDJ and DJing in general
If you need extended support, contact our Support Team.
Forum Guidelines  (*) The moderators hold the rights to remove, move or modify posts.
Topic: Automix Cue Points Not Working Properly...Maybe
I'm trying to setup a small automix playlist so I can step away when needed. The problem I have is when I add a cue point to the part that I would like to fade out of one song and mix into another, in the POI editor I change the cue point to 'Automix Point', select "Mix 'FADE' Exit Point the fade out section doesn't change to that area. In fact no matter what 'Automix Point' or Automix type is selected none adjust to the cue point that I'd like to fade the song out with. What am I doing wrong?
Posted Mon 12 Aug 19 @ 12:13 am
