Hello, I have just got a new Mac Book pro. I have connected and I am able to control VDJ through the MAC. However I am not getting any sounds through monitors and I also don't have DENONMCX8000 as a card selection in the "Audio" settings. Please help. I see Denon showing in "Controllers" but once clicked I do not see the Denon card showing in "Audio" as it should.
Posted Tue 16 Jul 19 @ 8:44 pm
maybe the vdj setup manual for that controller will help, its here https://virtualdj.com/manuals/hardware/denon/mcx8000/setup.html
Posted Tue 16 Jul 19 @ 9:23 pm
Even if there is no special button in the Audio tab for the MCX8000 (which it should), are you still able to manually select the MCX8000 sound card from the drop-downs and manually create the setup as shown here https://virtualdj.com/manuals/hardware/denon/mcx8000/setup.html , or not available at all and all you get is your computer's built-in sound card ?
Can you also check Audio MIDI Setup (from Utilities) and see if the MCX8000 sound card is there ? (screenshots would help)
Posted Tue 16 Jul 19 @ 9:44 pm
You need firmware and drivers for windows
https://www.denondj.com/downloads
MCX8000
Windows Driver
v1.0.5
Download
31.3 MB
Firmware
v2.1
Download
5.1 MB
User Guide
v1.1
Download
5 MB
Quickstart Guide
v1.2
Download
6.9 MB
Firmware Update Instructions
Download
390.4 KB
MIDI Command List
v1.0
Download
76.6 KB
MCX8000
Windows Driver
v1.0.5
Download
31.3 MB
Firmware
v2.1
Download
5.1 MB
User Guide
v1.1
Download
5 MB
Quickstart Guide
v1.2
Download
6.9 MB
Download
390.4 KB
MIDI Command List
v1.0
Download
76.6 KB
Posted Fri 02 Aug 19 @ 3:51 pm
altonbrinja wrote :
Why? The OP states he is using a new MacBook Pro. What use would Windows drivers be?
Posted Mon 05 Aug 19 @ 10:36 am
I am having the same issue with a macbook pro, OS 14.4. VDJ8 will not see it in the audio settings.
Side note - VDJ8 will see my DDJ-SB2 with no issues. Mac osx 10.14.4, MacBook Pro
Posted Tue 06 Aug 19 @ 6:54 pm
I have the same problem.
I tried on my MacBook which is OS Catalina 10.15.6 version and on my Mac mini OS High Sierra 10.13.6 version.
both of them have the same problem.
I install the mac driver from Denon website but nothing change.
can anyone help me pls?
Posted Tue 11 Aug 20 @ 3:23 am
Probably Mac security settings preventing the driver from installing.
This is well documented, if you research...
https://www.denondj.com/kb/macos-10-15-catalina-support-for-denon-dj/
Posted Tue 11 Aug 20 @ 7:49 am
MCX8000
Windows Driver
v1.0.5
Download
31.3 MB
Firmware
v2.1
Download
5.1 MB
User Guide
v1.1
Download
5 MB
Quickstart Guide
v1.2
Download
6.9 MB
Download
390.4 KB
MIDI Command List
v1.0
Download
76.6 KB
MCX8000
Windows Driver
v1.0.5
Download
31.3 MB
Firmware
v2.1
Download
5.1 MB
User Guide
v1.1
Download
5 MB
Quickstart Guide
v1.2
Download
6.9 MB
Download
390.4 KB
MIDI Command List
v1.0
Download
76.6 KB
I try that but still don’t work
Posted Sat 25 Nov 23 @ 1:15 pm
I see you are on Windows. If the driver is properly installed, you should see "Hardware Connected" .. when opening Control Panel from C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Denon DJ\MCX8000
In your Account stats i see .. :asio-Denon DJ MCX8000 ASIO:0/0 , which means the ASIO driver is not reporting any channels, probably not present/blocked - not sure.
Posted Sat 25 Nov 23 @ 2:16 pm
