Make sure you take full advantage of that free three months of Tidal.
Posted Fri 14 Aug 20 @ 6:56 pm
For those that are curious: The Hardware Manuals for all the Prime Series (Prime 2, Prime 4, SC5000(M), SC600(M), X1850) are already online and you can have a look at the displays and all the controls inside VDJ.
Posted Sat 15 Aug 20 @ 8:16 am
There's an error in this picture:
The left deck S (shift) is shown over the sync button. The shift button is on the right side.
Posted Sat 15 Aug 20 @ 10:28 am
~ removed double post ~
Posted Sat 15 Aug 20 @ 11:32 am
Not looked at tidal yet, need more hours in a day at min groove lol , but will look into it, nice feature having wifi, be nice to see spotify on there at some point
Posted Mon 17 Aug 20 @ 11:53 pm
Forget spotify, its for private use only, not for DJs.
Posted Tue 18 Aug 20 @ 12:14 am
Yeah, Spotify have now removed support from any/all DJ apps.
VDJ had it very briefly a few years ago, but it got removed due to a complaint from one of their providers who didn't want their material available in professional DJ software.
Now they've withdrawn completely, possibly because DJs tended to stream Spotify tracks from their phone/table at gigs regardless of Spotify T&Cs.
Posted Tue 18 Aug 20 @ 10:07 am
Denon Prime 4 is now supported in build 6067.
You may need to start VirtualDJ, wait a bit for it to update the controller definitions and restart for it to work.
Posted Tue 18 Aug 20 @ 2:12 pm
Yes I've just seen the post on the Denon forum:
Posted Tue 18 Aug 20 @ 2:17 pm
Posted Tue 18 Aug 20 @ 3:15 pm
The waves are still not flowing smoothly..
Is it normaly??
Is it normaly??
Posted Tue 18 Aug 20 @ 3:51 pm
Is it normaly??
Is it normaly??
If I remember right, there is a refresh-rate limitation of the Denon yes.
Not super duper smooth, but still nice ;-)
Posted Tue 18 Aug 20 @ 4:49 pm
Oh, no, a slideshow display. It already began with the first problems. Can you make a video of it?
Posted Tue 18 Aug 20 @ 6:15 pm
I find the waves to hard buggy :/
Posted Tue 18 Aug 20 @ 8:25 pm
Not getting the prime 4 out till weekend bud does the times come up in the deck lcd? That would be nice , and yes i recall spotify been on at some point but never mind , will look into tidal at weekend too
Posted Tue 18 Aug 20 @ 9:12 pm
Track times? sure does ;-)
https://virtualdj.com/manuals/hardware/denon/prime4/layout/screen.html
Posted Tue 18 Aug 20 @ 10:14 pm
I think he means the jog wheel displays - and the answer to that is no.
Posted Tue 18 Aug 20 @ 10:23 pm
Hello,
And been patiently waiting. Thanks for the awesome work. As you can see I've been a member for a while. I have followed instructions and updated everything. I got a message that some .exe file could not be found and to reinstall the program. (VDJ I guess, it was not specific) I did not copy the exact filename down but I did as I was told and re-downloaded VDJ 6067 and reinstalled. I no longer receive the message. In short, I still have no main screen and the audio stutters continuously. Yes, I installed the latest Denon windows drivers. The wheel screens work fine. The controller buttons and such seem fine too.
I am usually pretty good with this, but hey, I could be missing something?..
Win 8.1
i5
12 Gb Mem
Prime 4 connected via USB 3
PC only used for VDJ
Win 8.1
i5
12 Gb Mem
Posted Tue 18 Aug 20 @ 10:37 pm
W...
Wi..
Win 8?
Then the i5 seems to be 3rd generation and with ddr3?
I guess your computer is overloaded with the Stems math.
Disable Stems math, or better, buy a new computer... :c)
Wi..
Win 8?
Posted Tue 18 Aug 20 @ 10:47 pm
Yes windows 8.1
Non-stems version 32bit. So.... no stems to disable...
64 bit OS
DJ DAD, any clue?
64 bit OS
DJ DAD, any clue?
Posted Tue 18 Aug 20 @ 10:54 pm
