Topic: Denon Prime 4 Virtual Dj Support - Page: 12
Guys, we understand the anticipation and probably a frustration, and need to reassure you that the projects are still alive and worked daily. As for the ETA, we really can't tell because it's not in our hands completely and issues may occur till last minute.
Both Atomix and Denon Development Teams are working to bring support for all Prime devices as soon as possible.
Feel free to bump this topic daily, or email Denon, but trust me, it wont make any difference in arrival date, so just sit back and wait for the good news.,
Posted Fri 05 Jun 20 @ 9:39 pm
We have waited so long so a little bit longer will not hurt. Big up the team to get this right
Posted Sat 06 Jun 20 @ 1:31 pm
A NEW SKIN HAS ARRIVED
Posted Sat 06 Jun 20 @ 4:18 pm
WORKING FINE, THANK YOU TO ALL THAT MADE THIS HAPPEN
Posted Sat 06 Jun 20 @ 4:25 pm
djcraigPRO InfinityMember since 2006
Are you saying the screen on the Prime 4 now works with VDJ?
Posted Sat 06 Jun 20 @ 6:45 pm
working ok. only prob i got is the wave form direction. mine is up and down i want to go across like vdj8
Posted Sat 06 Jun 20 @ 8:00 pm
just worked it out they is a select button on screen which you can switch
Posted Sat 06 Jun 20 @ 8:12 pm
Struggling with that.
Are you saying you have changed the waveform to horizontal?
Posted Sat 06 Jun 20 @ 8:54 pm
that is correct. select button on screen to change it
Posted Sun 07 Jun 20 @ 12:26 am
Does the Jogwheel works too? Artwork?
Posted Sun 07 Jun 20 @ 6:56 am
Still cant find the select button.
Have you got a photo of the select button?
Posted Sun 07 Jun 20 @ 8:14 am
I assume they will, as the rings do rotate on the screen, i just dont use artwork.
What would be better for me is time of song elapsed and remaining
Posted Sun 07 Jun 20 @ 8:23 am
Okay ..
Have anybody the Package from few days from the Jogwheels ?
Because Atomix delete it after 2 Days..
The Jogwheel artwork you can also download before the given time.
Posted Sun 07 Jun 20 @ 8:40 am
If I remember correctly, Atomix uploaded it to test that it would download to the connected hardware automatically. Not to make it available to everyone.
As people keep repeating to you - it will be ready when it's ready.
Posted Sun 07 Jun 20 @ 8:52 am
Well, for 30 mins i played around with it, i was impressed.
I was also glad to unbox my prime 4 after having it 7/8 months hidden in the loft from the missus. Great piece of equipment.
With VDJ it will be fantastic.
Posted Sun 07 Jun 20 @ 9:16 am
Have you found that button yet? :-)
I can't see one either, but I just ran the skin on my PC after hacking the XML file to have a look.
Posted Sun 07 Jun 20 @ 9:38 am
@djcraig - haha :D the womensss :D, have you perhaps the jogwheel package which was uploadet for few days?
Yes I test it to and it works very good!! Nice work!!
I only have have the problems too with the horizonal wave forms? I dont find the button to change it
according to the xml you can activate the album artworks, but how? I found this code.
<panel name="DNS_jog" group="DNS_settings" visible="no">
<panel class="denonsetting" x="200" y="120" text="Show Album Art on Jog Display" text1="No" text2="Yes" action3="set '$denonsetjog' 0" action1="set '@$denonshowjogalbum' 1" action2="set '@$denonshowjogalbum' 0"/>
<panel class="denonsetting" x="200" y="120+80" text="Jog Display Brightness" text1="-" text2="+" action3="set '$denonsetjog' 1" action1="var &apos;@$prime4_brightness&apos; 10 ? nothing : cycle &apos;@$prime4_brightness&apos; +11" action2="var &apos;@$prime4_brightness&apos; 0 ? nothing : cycle &apos;@$prime4_brightness&apos; -11"/>
<textzone>
<pos x="200+10+590-120-20" y="120+80"/>
<size width="120" height="70"/>
<text fontsize="26" align="right" color="#909090" action="get_text &quot;`get_var '@$prime4_brightness' & param_multiply -10 & param_add 100` %&quot;"/>
</textzone>
<textzone visibility="var '$denonsetjog' 0">
<pos x="240" y="800-135"/>
<size width="1280-30-240" height="60"/>
<text fontsize="20" align="left" color="#707070" text="Choose Yes, if you want the Album Art of the loaded Track to be displayed on the Jogwheel Display"/>
</textzone>
<textzone visibility="var '$denonsetjog' 1">
<text fontsize="20" align="left" color="#707070" text="Adjust the Brightness of the Jogwheel Display"/>
</textzone>
</panel>
Posted Sun 07 Jun 20 @ 9:51 am
I think maybe some of the code in the Prime 4 screen skin is linked to code in the mapping or data sent from the hardware.
I can't get the SC5000 skin to appear in VDJ on my computer at all. It's just blank. There must be something else going on. :-)
Posted Sun 07 Jun 20 @ 10:03 am
you can only change waveform on the laptop. if you look to right of screen you will see a button saying select, you can change colour of jog wheels here. also change waveform. Dont know if you can do it on the screen of the denon prime. i noticed when using asio drives all work well but if you change it some buttons on controller will not work. Also using asio drives my output for broadcasting is very low, cant get a signal in to boost volume. But still very happy.
Posted Sun 07 Jun 20 @ 1:39 pm
45%
