Topic: VDj 2K18 : Sound Card
Hello,
I recently installed Virtual DJ 2018, and I wanted to start playing some sound.
The small problem is that no sound comes out.
Indeed on my pc I do not have a sound card.
Using a Blue Bird SL XLR microphone I use a console BEHRINGER - XENYX 302USB.
So I would like to know if there is a possibility that VDj works by exploiting this console or that is impossible?
Posted Sat 18 May 19 @ 1:12 pm
NicotuxHome userMember since 2014
Hello,
As all the Behringer Xenix USB serie the 302USB is detected as a standard usb audio device with 2 stereo channels whenever you already have a sound card or not
The only problem reside in the configuration of the red and 2 grey buttons Line in/usb FROM and TO and 2-track TO
with VDJ config master set to USB-AUDIO chanel 1&2 and headphone to USB-AUDIO chanel 3,4 everything must be ok
depending on system the device name USB-AUDIO may be a little different but will mostly contains the word USB
Posted Sat 18 May 19 @ 9:23 pm
