Topic: Is it possible to clear a deck
GP McDHome userMember since 2016
I'm sure this is probably a stupid question, but, if I want to remove a track from a deck so that the deck is empty, how do I do that?
I was watching a YouTube tutorial on another topic and I swear I saw the instructor clear a track from a deck by clicking somewhere inside the deck area, but I can't find how to do it. All I'm wanting to do is just clear a deck where it's empty so I can do some cue work on the other deck and not have to be looking at 2 tracks in the waveform window. Right now I'm just closing VDJ and opening it up again but there's go to be a better way. I appreciate any help.
Posted Thu 16 May 19 @ 11:40 pm
it depends what SKIN you use but you can assign a key shortcut to UNLOAD the deck
ex: deck 1 unload
Posted Thu 16 May 19 @ 11:43 pm
Thank you so much!
Posted Fri 17 May 19 @ 12:53 am
NicotuxHome userMember since 2014
In example: using default skin it's right "click and hold" the stop button
Posted Fri 17 May 19 @ 1:25 am
or just right click and hold on the pause button. that works too
Posted Fri 17 May 19 @ 7:17 am
You really should read the VDJ manual....
Posted Fri 17 May 19 @ 5:56 pm
Right click and hold for 2 seconds will not clear the deck in a 2 deck set up on my MacBook Virtual DJ using the default display.
Posted Fri 27 Dec 19 @ 8:18 pm
