Topic: b4909 and Problem with the Skin [solved[
djnoaiPRO (legacy)Member since 2017
Since BUILD 4909 (2019-04-25) i have a problem only with the skin "The Thing":
After a few minutes (or whatever i do!!? start stop automix!?) i can no longer jump with the mouse in the waveform to any other positions.
It´s like the screen would be locked.
If i change to the default skin, it works there again.
I tested it without a connected controller, just in keyboard modus!
If i go back to build 4808, the skin "The Thing" works again normally.
Posted Mon 29 Apr 19 @ 7:10 pm
Someone else reported this in another skin too!
Posted Mon 29 Apr 19 @ 7:27 pm
Looks like this one is Waveform Markers turn them off for now.
Posted Mon 29 Apr 19 @ 8:49 pm
Locodog, you are right!
If I set the Waveform Markers off in the skins options, it will work again.
My question is: Is it enough to wait until a new update fixes the problem or do I have to contact the skin developer?
Posted Tue 30 Apr 19 @ 7:46 am
In general the skin developers needs to update their skins for the new features added
(that's the bad part about creating a skin that becomes popular - you will need to do support and updates forever :) )
Posted Tue 30 Apr 19 @ 8:33 am
Probably wait a bit.
Looking at the XML, I think the issue is the same as with the FRUiT skin (fix given by djdad) - the mouserect code is set to zero pixels.
A bug fix is coming though.
Posted Tue 30 Apr 19 @ 6:31 pm
