Hi,
Very good idea. Same happens when a slideshow use a portrait photo , o any square size that doesn’t fill the widescreen ,
Thanks in advance
GK
Thanks in advance
GK
Posted Fri 29 Mar 19 @ 5:33 pm
Now available in 4844 early access.
(No detection or removal of black bars that are encoded in the video yet though)
To use, install 'Blur Black Bars' from Config->Extensions->Video effects, then select and activate on each deck (not on the master)
Whenever you load a video with different aspect ratio from your output, blurred bars will be added.
Posted Sun 07 Apr 19 @ 3:09 pm
Working great here!! Thank you!! This is much needed and long overdue in my opinion.
Posted Sun 07 Apr 19 @ 8:31 pm
Can you (someone) post some pics of how it looks?
Posted Sun 07 Apr 19 @ 8:44 pm
The forums won't let me upload my screen shots, I guess they're too big
But here's both vertical and horizontal,
http://tinypic.com/r/90pxc0/9
http://tinypic.com/r/6qbrlt/9
Posted Sun 07 Apr 19 @ 8:58 pm
I do think this should be added in the options tab tho under video.
Reason being, I don’t wanna have to activate this every time I open VDJ. I like set it and forget type things, lol!!
Posted Sun 07 Apr 19 @ 9:45 pm
Yes, this is for testing, will probably add it as an extra option for letterboxing.
Posted Mon 08 Apr 19 @ 3:14 am
Works very well, the only thing is that i have the resetfxonload activated, so when a i load i new song it deactivates the blur,
thx
GK
thx
GK
Posted Mon 08 Apr 19 @ 5:12 am
Excelent. ! No More 4:3 s
GK.
GK.
Posted Mon 08 Apr 19 @ 7:45 pm
Could we get a height and witdth parameters added??
Posted Wed 10 Apr 19 @ 7:33 pm
