Topic: Roland DJ 505 - A Good Replacement Or Not - Page: 2
locodog wrote :
So you reply, "don't use the program you want to"...
No I did not. Please stop reading between the lines.
I simply stated that he didn't need to use OBS with VirtualDJ. Stating facts to try and help the guy.
Posted Sat 30 Sep 23 @ 4:50 pm
tonz76PRO SubscriberMember since 2021
Posted Sun 01 Oct 23 @ 6:00 am
groovindj wrote :
You don't need to use OBS. VirtualDJ has streaming built in. You can stream directly.
Thanks, I had read about this option but use OBS with def scenes etc.
Looks like I might have finally found the solution in OBS and it was all around the audio capture set up. I had selected audio output capture but seems I needed the audio input capture for it to work along with the correct vdj outputs.
Posted Sun 01 Oct 23 @ 6:11 am
