I've recently started noticing a problem (i.e. 1-2 weeks ago), whereby clicking on say 'Virtual Folder1' that contains a list of files, will show no files. To be clear, there are no filters on, nothing typed in the search box, no ongoing searches, etc. Clicking on say 'Virtual Folder2' and then clicking 'Virtual Folder1' does not remediate the problem (the thought process being something simply in the view is causing it). The problem is not consistent --- in other words I haven't found a definitive way to trigger it. Further, when it does occur, it affects a single virtual folder --- so not all virtual folders are affected. Also, the same virtual folder isn't affected each time, so it isn't a problem with any one specific virtual folder.
***The problem can be remediated by restarting VDJ, at which point all files will once again show up under 'Virtual Folder1'. This is a bit of pain since during a party, etc., you don't necessarily want to have to restart VDJ to see the Virtual Folder contents.
Sorry, I don't have much more information on the root cause at this point.
Posted Tue 25 Dec 18 @ 6:15 pm
Do the files come from multiple drives perhaps?
Posted Tue 25 Dec 18 @ 6:42 pm
Hey Adion, Merry Christmas btw! I'm on a desktop computer. I have a C drive, which runs my primary OS. I have two RAID-1 - 4 TB drives that serve as my D: drive. All of the virtual folders contain music from the D drive and some music from the C drive. When I've observed the issue, I've found the problem to exist with a virtual folder that contains files from only the D drive, and from a virtual folder that contains files from both the C and D drives. (If it helps, I've never had this issue before and been running the same setup for years)
Interesting update, if during the time period where the virtual folder shows blank, I try to add a new file to the folder, upon the next restart, the folder will only have that one file! I checked the corresponding 'vdjfolder' contents and confirmed that it indeed overwrites that file with the one entry. Luckily, I backup the entire VDJ directory often enough, so I just had to restore that one affected file.
Any help would be much appreciated! This is a bit scary!
Posted Wed 26 Dec 18 @ 12:43 am
and here I thought it was my ancient desktop at work having this issue.
current public build does this.
I had the same problem with virtual folders being empty even of files that aren't on the drive that was removed. thumbdrives in this case. the folder would only repopulate when I put the drives back in. drove me a little nuts the first time because I could get zero search results as mentioned above.
Posted Thu 27 Dec 18 @ 8:26 pm
I have the same problem with virtual folders. Has someone got a solution for this problem?
Thanks
Thanks
Posted Wed 02 Jan 19 @ 10:58 am
Had the same thing happen this past Saturday night, I thought it was something I did but seems it’s an issue with VDJ
Posted Wed 02 Jan 19 @ 4:46 pm
Happened again last night but this time I took a video
They never showed up for the rest of the night either.
Posted Sat 05 Jan 19 @ 2:57 pm
