Topic: Problem with broadcasting & virtual DJ. 2018
Good evening to friends & colleagues
I try to live live from the virtual dj server,
I have opened the 8000 door & on my page it says:
Success
Dj is live and broadcasting
But i just hit the play
Does nothing . I tried it with every device, computer, mobile / tablet,
And not just with my own, but with others and it does not work. Any idea?
I would like to say that when broadcast through shoutcast i do not have any problems.
Also i'm trying to broadcast through, Facebook, You Tube, Twitch, etc.
Theoretically you connect and work, but the picture is sticking, and there is no sound at all. Also, the program warns me that i need to download the bitrate. I lower it as much as the program allows, but nothing else. Also, i would like to inform you that when i broadcasting with OBS (open broadcaster software) i am not experiencing any problems. Some idea here ?
Posted Mon 08 Oct 18 @ 11:01 pm
if you can make it work fine with OBS i would continue using it since it is way more flexible then VDJ itself.
just a suggestion :-)
Posted Mon 08 Oct 18 @ 11:25 pm
