Hi
I am trying to do a remote skin with sample buttons and am trying to get the button to be the color assigned to the sample but can't work out what I am doing wrong.
I have defined a basic class
<define class="samplepad" >
<visual type="color">
<pos x="+0" y="+0"/>
<size width="150" height="120"/>
</visual>
<button >
</button>
<textzone>
<pos x="+10" y="+55"/>
<size width="130" height="20"/>
<text size="20" align="center" weight="bold"/>
</textzone>
</define>
then use it like this
<panel class="samplepad" x="+0" y="+0">
<visual source="sampler_loaded 1 ? get_sample_color 1 : constant '#888888'"></visual>
<button action="sampler_pad 1"></button>
<textzone><text action="get_sample_name 1"/></textzone>
</panel>
but the button background is always black (I have also tried just 'sampler_color 1' but that has the same result.
Any help would be greatly appreciated.
</visual>
<button >
</button>
<textzone>
</textzone>
</define>
</panel>
Posted Wed 19 Sep 18 @ 5:42 pm
Basically you draw your button on top of your visual with the exact same position and dimensions.
This means that the button graphics will always hide your color visual.
You need to either reverse the drawing order (so that the visual draws on top of the button) or adjust the position and size of each element so that they don't overlap (or at least don't overlap completely)
Posted Fri 21 Sep 18 @ 11:45 am
Hmm, not sure about this.. the button doesn't have any graphics, so it shouldn't overlap the visual. Do you get the color if you remove the button ?
Can you try sampler_color 1 a instead of get_sample_color 1 ?
You can also troubleshoot by changing
with
<textzone><text action="get_sample_color 1"/></textzone>
and see if you get its color as text.
with
Posted Fri 21 Sep 18 @ 2:00 pm
Hi DJ Dad
Removing the button makes no difference.
However most telling is if I change the textzone as you suggested to
the text field is blank (I did make sure the sample had a color).
I also tried <text action="sampler_color 1"/> that resulted in nothing also.
Posted Sat 22 Sep 18 @ 2:56 pm
Is this also the case with a default sampler bank, such as the Instruments bank ?
Edit: Ah you are making s remote skin, i wonder if this has to do anything with your issue, i ll have a look here too
Posted Sun 23 Sep 18 @ 9:02 am
Hi
It won't get the color on any of the banks, including the pre-existing ones likes "Instruments".
I tried using the Remote Skin I had created as the main skin for VDJ and it works fine, with the button showing up as the color of the sample, so this must be related to Remote Skins only.
Posted Thu 27 Sep 18 @ 4:29 pm
The problem has been found, and it will be fixed in the next VirtualDJ update.
It was a problem with the way VirtualDJ sent color data to the remote.
Posted Thu 27 Sep 18 @ 4:31 pm
Great thanks
Posted Fri 28 Sep 18 @ 1:48 pm
