About VirtualDJ and DJing in general
If you need extended support, contact our Support Team.
Forum Guidelines  (*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
Topic: Sticker Lock - The ONLY thing left that SERATO does better than Virtual dj , Adion get to work!!!!
avery416PRO SubscriberMember since 2017
The ONLY thing that SERATO has over Virtual DJ is "sticker lock" feature on doubles (clone deck) or instant doubles as SERATO calls it for juggling 2 copies of the same song with NO drifting. SERATO has no drifting at all.
This is the #1 reason why hardcore scratch turntablists choose SERATO over every one else. Period, don't care if you like it or not it is true.Every other feature can be done on Virtual dj now.
Adion no excuses man! Or whoever is responsible for writing the code, crack the f@#king SERATO secret of sticker lock to get the hardcore turntablist djs to finally leave SERATO. Stop the damn drifting in relative mode even when not using hotcues.
Let's REALLY see how good your programming skills are. STICKER LOCK IS THE MOST IMPORTANT FEATURE NEXT TO REALISTIC SCRATCHING IN PREFORMANCE. In caps if you don't get it. So get busy no excuses! Fix the drifting!
Posted Sun 16 Sep 18 @ 11:12 pm
lower the "timecode silence" setting to zero, or 0.01, and you wont have any drift, IMO it is tighter than Serato.
IMO the only thing better in Serato are the Scratchwaves...
Posted Tue 18 Sep 18 @ 9:13 am
vdj_pARtybOy thanks for the tip, if you can fine tune the drift in increments that is better than SERATO 's sticker drift which is only on or off.
Trust me I WILL be testing that, along with a couple of DMC/IDA cats to verify that. If that claim is true trust me VDJ 2018 in my opinion is king control vinyl DVS no question.
Posted Tue 18 Sep 18 @ 11:02 pm
meh VDJ effects are far behind Serato's
Posted Wed 19 Sep 18 @ 2:21 am
That was back in the v7 days :)
Also remember that VDJ effects is basically all effects since .vst is supported so there really are no limits in VDJ anymore when it comes to effects
Posted Wed 19 Sep 18 @ 6:28 am
VDJ has supported VST effects since version 2, which was in 2004.
Posted Wed 19 Sep 18 @ 4:23 pm
