I need to route the Program & Que audio to different 5.1 sound card outputs...
Windows 7 OS and the sound card is a C Media 18738 PCI express card (a lot of these are on ebay).
I have a specific need to these to NOT come out the MAIN (front audio) which is used for automation.
I'd like for the VDJ Program audio to come out the SIDE channels, and the VDJ Que audio to come out the center / bass / rear.
THANKS for any technical help here (we're switching to a new computer)
Posted Tue 28 Aug 18 @ 10:54 pm
I use a controller myself so can’t offer help specific to your configuration. But have you tried reading the manual on audio configuration? It’s here:
https://www.virtualdj.com/manuals/virtualdj/settings/audiosetup.html
Explanation is quite understandable. Once you’ve selected your sound card in the config you could post a picture if you’re still stuck and someone here will be able to help.
Posted Wed 29 Aug 18 @ 3:15 am
