The audio effect "LoopOut' and or "Loop Out" is behaving like loop roll when activated in BUILD 4444 (2018-06-19). I seen you guys updated this effect to include video etc in the new built. I reverted back to v8.2 b4291 for the very reason when I use "loop out" it visually captured the direct part to loop out as per image.
Please incorporate "loop out" behavior in the new built or leave this audio effect as an option going forward. Thank you.
Posted Sun 01 Jul 18 @ 2:01 pm
early access b4459 - Loop Out is looping out just like it's supposed to as far as I can tll
Posted Sun 01 Jul 18 @ 2:14 pm
Come on man, you know the score when an fx that you downloaded isn't shown in vdj anymore, rename the fx.
Posted Sun 01 Jul 18 @ 4:46 pm
Trying early access b4459 still does not get what I'm accustom to after using this for many many years ago.. Let me ask you, does your Loop out NOW when selected or active either using a keyboard or a controller when say loop out on a 4 beat does the 4 beats on the waveform get highlighted/ shaded or whatever you call it like the image above? However previous versions what how it was.
My brotha, all I did was to accept the VDJ new updates only no effects was downloaded the fx in question is still there, however I tried to rename the existing Fx as you hinted to no avail.
Posted Sun 01 Jul 18 @ 9:43 pm
you miss understand,
the loop Out you like, was downloaded by you time ago. the vdj18 update has a native fx called loop Out inside it, so what the devs have done is make the program ignore the dll called loop out and use the one native to vdj, if you remane the dll. and come back to the vdj18 release you'll have both.
As always test, I think this was just out with the old in with the new, but there could be more to it.
Posted Sun 01 Jul 18 @ 9:51 pm
@ locodog you're right.
Posted Sun 01 Jul 18 @ 10:18 pm
find the native one in the drop down list and right click and more to ignore
Posted Sun 01 Jul 18 @ 10:32 pm
thx
Posted Sun 01 Jul 18 @ 10:34 pm
