Hello,
When I create a virtual folder and want to move it, I often have the problem that I cannot insert it into an existing folder.
I try this by drag & drop.
It also happened that the virtual folder disappeared completely.
Perhaps someone has had a similar problem before? In the forum, many users have reported the problem that has been recurring since version 8.2. At the last gig I had created a folder with music requests, which was then suddenly gone. And that's exactly what happens when I want to move folders, for example. It has already been reported several times to Atomix by different users, but it has not been fixed.
Posted Sun 27 May 18 @ 9:35 am
