I'm using numark mixtrack pro II.
I want to assign different VDJscripts to both sides of FX buttons.
Can I do it?
Can I do it?
Posted Fri 17 Jul 20 @ 3:15 pm
Posted Fri 17 Jul 20 @ 3:16 pm
Can I do it?
Can I do it?
Yes! Just use
action_deck numas a query. For example:
action_deck 1 ? play : pause
This will be a play button on deck one, and a pause button on all other decks.
Posted Fri 17 Jul 20 @ 7:12 pm
For example, I want to assign VDJscripts indicated in this attached file.
Posted Sat 18 Jul 20 @ 2:52 pm
Posted Sat 18 Jul 20 @ 2:53 pm
Whichever I push left or right FX1 button of mixtrack pro II(indicated in the above picture), FX1 is detected as Key.
How does VirtualDJ distinguish right from left of FX1 buttons?
Posted Mon 20 Jul 20 @ 3:21 pm
action deck X ? FOR DECK X : NOT FOR DECK X
Posted Mon 20 Jul 20 @ 3:47 pm
Then I cannot realize this assignment?
https://www.virtualdj.com/img/317225/47626/mixtrackpro2.jpg
Posted Mon 20 Jul 20 @ 4:19 pm
Why not?
action deck 1 ? os2l_button 'blackout' : nothing
action deck 2 ? os2l_button 'strobe' : nothing
Posted Mon 20 Jul 20 @ 4:21 pm
Can we write multiline VDJscript as Action like this?
Posted Tue 21 Jul 20 @ 1:34 pm
Hello, I think this might be a solution:
action deck 1 ? os2l_button 'RED' : action deck 2 ? os2l_button 'GREEN' : nothing
Posted Tue 21 Jul 20 @ 1:49 pm
I've just confirmed that this VDJscript below works well.
action_deck 1 ? os2l_button "Red" : os2l_button "Green"
Posted Tue 21 Jul 20 @ 1:52 pm
hello
I am building custom pad (already done with help of locodog)they are reacting like "ableton" with quantise before next Cue..But my question is about the name of my pad...I want to give the name of the hot_cue (pad1--hotcue 1'name..Pad 2 __hotcue 2 'name') but in the empty text field of Name, no script seems to work...I know that i already talk about this here but I don't find the old threat...
Posted Thu 10 Dec 20 @ 4:19 pm
if I understand, you want
Pad 1 name: `cue_name 1`
Posted Thu 10 Dec 20 @ 4:32 pm
or if you wanna have different alternative (name, number, position) depending on cueDisplay setting :
Pad 1 map Name to : `cue_display 1`
Posted Thu 10 Dec 20 @ 5:13 pm
exactly
Posted Thu 10 Dec 20 @ 6:36 pm
skyzo76 wrote :
exactly
exactly
ok so..i understand that I don't know what is this character not a " not a '..and when i copy paste your code it works...(but i already tried it with ") OK so it was so simply thanks again locodog
Posted Thu 10 Dec 20 @ 6:52 pm
It's a backtick [has a few names, you should see it above your tab key]
https://www.computerhope.com/jargon/b/backquot.htm
in vdj script backticks [`] are used in a few places, mostly when dealing with text, it tells vdj to use what is inside two back ticks as a script, and then parse it as text
for example, you set a variable to 6.
set 'myVar' 6
you could give a pad name something like this
myVar is `get_var 'myVar'`
what would be displayed is
myVar is 6
backticks have uses in more advanced script than just text, but the purpose is the same. parsing script,
set 'myVarSquare' `param_multiply "get_var 'myVar'" "get_var 'myVar'"`
it can be a little confusing when you need to use backticks as some param_ modifiers are expecting a script so they don't need backticks, other param_ modifiers might expect a script or a string so backticks are need to indicated we have passed it a script.
It's just one of those that you learn with practice.
set 'myVar' 6
myVar is 6
Posted Thu 10 Dec 20 @ 8:08 pm
Hello Friends, excellent forum.
Please can you help me to create a script or command to execute the progressive "Filter" effect, or a curve for increase or decrease Filter sound fx, by clicking a single button or key. Thanks in advance.
As it the trail or route made by the potentiometer or filter knob, but by pressing a single key. May be trailing Filter fx from 30% to 80%.
Posted Fri 11 Dec 20 @ 2:59 pm
repeat_start 'filterTwist' ? repeat_stop 'filterTwist' : repeat_start 'filterTwist' 33ms -1 & filter 0% ? repeat_stop 'filterTwist' : filter +0.5%
something like that is the most basic way, I have virtualFX that can do it a bit more advanced, from a position, to a position, over a beat duration.
if you want that post in the virtualFX thread and I'll tweak the one I have here.
Posted Fri 11 Dec 20 @ 4:36 pm
