@sofit nothing existing, you could make your own thing with a rsi, I'll pick at it because it's a little more involved that 1 value
Posted Mon 09 Dec 24 @ 10:26 pm
I just watched the youtube video on scripting and I think im way out of my league.
Im trying to make a button that will fadeout the current song, pause and cue the next song in my automix playlist.
I would also like this button to work with the karaoke playlist. if this is possible please let me know.
thanks
John
thanks
John
Posted Tue 10 Dec 24 @ 3:49 pm
I really dislike writing scripts for automix, too may options come into play, karaoke makes it even worse.
Posted Tue 10 Dec 24 @ 4:37 pm
My annual thanks to all that help out on the forum (particularly locodog) and a question:
Is there a vdj script command to delete a (browsed) file that first moves the file into the recycle bin, so I can catch accidental deletions (rather than the hard delete)?
Posted Wed 11 Dec 24 @ 12:41 pm
You can't delete files with script, only with rightclick can you delete and then it's a operating system decision where the deleted file goes [recycling or hard delete]
Posted Wed 11 Dec 24 @ 6:18 pm
hi, i have this problem, i have mapped a controller button “eq_mode +1” to change mixer knobs..but when use knobs in automatic mixer kobs return in low-mid-high function….mixer knobs are mapped:
eq_low
eq_mid
eq_high
this scripts are wrong?
thanks!
eq_low
eq_mid
eq_high
thanks!
Posted Sat 14 Dec 24 @ 4:46 pm
Is there a way to scratch just the length of one beat? I think the length of time can be calculated as 60/BPM seconds,
but I would like to use this calculation formula as an argument for scratch.
Posted Wed 15 Jan 25 @ 5:53 pm
@twaga I think the scratch verb is only used for BASIC testing purposes.
But to answer the question, mainly to show how to get ms/beat values
first one is a more recent way
we get a constant 1, we cast it as beats, we then cast that beat to ms and it gives us ms/beat, and because scratch expects a +/- value we cast it one more time to a relative value and that puts it on the end of the scratch verb as a relative ms value.
second one
we don't have a divide verb, but we do have a parameter manipulation of
1 / parameter
we then multiply by 60000 [the number of ms in a minute]
and as before cast as relative.
But as I said before the scratch verb is VERY BASIC
If you're looking for scratch on a button press, you should look at this.
https://www.virtualdj.com/wiki/ScratchDNA.html
get_constant 1 & param_cast beats & param_cast ms & param_cast relative & scratch
get_bpm & param_1_x & param_multiply 60000 & param_cast ms & param_cast relative & scratch
second one
1 / parameter
Posted Wed 15 Jan 25 @ 7:32 pm
Thank you. I have confirmed the correct behavior of your script. I know about scratchDNA, and we can adjust the size of the scratch using the alphabet.
But although we can adjust the timing based on the beat, I don't think we can adjust the size of the scratch based on the beat.
Is it possible to play only one beat and then pause by VDJscript?
Posted Thu 16 Jan 25 @ 12:09 am
play & wait 1bt & pause
I tried this script, but it seems that the small amount of time it takes for the play command causes small error and shifts.
Posted Thu 16 Jan 25 @ 12:20 am
I think that a loop action can be used to play exactly one beat, but can we create a script that specifies the number of loops and loops one beat only once?
Posted Thu 16 Jan 25 @ 6:18 am
I tried to imitate this and write a script that scratches back from the current position to the cuepoint, but the script below didn't work.. Could you please tell me the correct way to write it?
get_position & param_multiply -1 & param_add 'cue_pos 1 mseconly' & param_cast ms & param_cast relative & scratch
Sorry for writing so many times.
If I can make this script correctly, we can use the script with the script of scratching 1 beat taught by you and stutter, I think it will be possible to create a more flexible scratch than scratchDNA using manual keyboard operations.
Posted Thu 16 Jan 25 @ 4:27 pm
get_position returns a value of 0.0 to 1.0, not a time,
try get_time elapsed
Also
cue_pos 1 mseconly is not pitch adjusted, use this instead
`get_time cue1 1000`
Also
Posted Thu 16 Jan 25 @ 5:09 pm
You can make the beat to milliseconds part a little bit shorter btw
constant 1bt & param_cast ms
Posted Thu 16 Jan 25 @ 6:03 pm
@adion nice addition, thanks for the info.
Posted Thu 16 Jan 25 @ 6:09 pm
This script worked very well! Thank you very much.
param_add 'get_time cue1 1000' 'get_time elapsed & param_cast relative & param_multiply -1'& param_cast ms & param_cast relative & scratch
Posted Fri 17 Jan 25 @ 12:04 am
This script made it easier! thank you!
constant 1bt & param_cast ms & param_cast relative & scratch
Posted Fri 17 Jan 25 @ 12:07 am
However, I found that this script works while pausing, but not while playing.
How can I make it work even during playing?
Posted Fri 17 Jan 25 @ 4:24 pm
pause & param_add 'get_time cue1 1000' 'get_time elapsed & param_cast relative & param_multiply -1'& param_cast ms & param_cast relative & scratch
I solved it by adding pause at the beginning.
Posted Fri 17 Jan 25 @ 5:14 pm
Regardless of the value of the scratch argument, the time it takes to one scratch seems to be constant. Is it possible to adjust the speed?
Posted Sat 18 Jan 25 @ 9:13 am
