Hey Script-Pros,
is it possible to have "controllerTakeoverMode"="gradual" for gain knob only. Is it possible to read the controller knob position of a knob or slider using VDJ script, when it isn't synchronous with the software position. All the scripts seam to report the software-position.
Thx in advance!
Cheers
Jochen
Thx in advance!
Cheers
Jochen
Posted Tue 10 Jan 23 @ 9:09 pm
@EGR if every dial command changed the setting and changed back, maybe.
setting controllerTakeoverMode "instant" & level & setting controllerTakeoverMode "gradual"
Posted Wed 11 Jan 23 @ 4:11 am
@LOCODOG,
that is a very good idea and may do the trick. Will check it in the evening, when I'm back home.
I said it may times and have to do it again.
This community is awesome. Thx a lot for your quick and helpful answers!
Cheers
Jochen
Cheers
Jochen
Posted Wed 11 Jan 23 @ 7:04 am
Hey LocoDog,
checkt your idea and it worked! Thx a lot!
Everything is on "pickup" except gain:
Cheers
Jochen
setting controllerTakeoverMode "gradual" & gain & setting controllerTakeoverMode "pickup"
Cheers
Jochen
Posted Thu 12 Jan 23 @ 12:11 pm
How to add strings [append a tag example]
quick one, save the text I want to add,
set a temp var, adding the thing I want to add to the thing I want to add to
grab the var, cast it as text, cast it to the thing I want to change
or even briefer
even briefer still, and in the order that doesn't hurt my primitive brain
Without a variable
set_var string " text I want to add" &
set temp `param_add 'get_var string' 'get_browsed_song comment'` &
get_var temp & param_cast 'text' & browsed_song "comment"
or even briefer
get_text "`param_add 'get_var string' 'get_browsed_song comment'`" &
param_cast & browsed_song comment
get_text "`get_browsed_song comment``get_var string`" &
Without a variable
get_text "`get_browsed_song comment` myTextToAdd" & param_cast & browsed_song comment
Posted Mon 23 Jan 23 @ 2:19 am
locodog wrote :
How to add strings [append a tag example] ....
Thats a very usefull script... Thanks for sharing ... i love it. <3
Posted Mon 23 Jan 23 @ 11:22 am
Hey everybody,
I try to create a day-theme for the Prime GO.
Everythings looks great except the bowser list.
How can I change the colors of the browser list?
Here are the elements the default theme is using:
How can I change colors in the design-tag?
Thx Jochen
<define class="primebrowser">
<font fontsize="24"/>
<fontheader fontsize="22"/>
<fontsearch fontsize="16"/>
</define>
<filelist class="primebrowser" headerheight="[LINEHEIGHT]" lineheight="[LINEHEIGHT]">
<pos x="+0" y="+50"/>
<size width="[BRWIDTH]" height="[BRHEIGHT]-50"/>
</filelist>
Thx Jochen
Posted Sun 05 Feb 23 @ 3:14 pm
@EGR a question better suited for the skins forum.
Posted Sun 05 Feb 23 @ 3:19 pm
Electronic Green Room wrote :
Hey everybody,
I try to create a day-theme for the Prime GO. ....
add in the <define class="primebrowser"...> the COLOR children.
https://www.virtualdj.com/wiki/Skin%20Browser.html
When you need mor help please post in the Skin Forum.
Posted Sun 05 Feb 23 @ 3:35 pm
hello, help me assign a button so that when you turn it on, the effect 'reverb' and stems fx 'vocal' are activated, and when you press the button again, the effect 'reverb' and stems fx 'vocal' disconnected.
something like this, but it doesn't work: deck right effect_active 'reverb' & effect_stems 'vocal' on : effect_stems off
Posted Mon 27 Feb 23 @ 7:02 pm
happened!!! it works: deck right effect_active 'reverb' ? effect_stems 'vocal' on : effect_stems off
now the question is how to register so that the button blinks when the effect is on and burns when it is off?
I used to have this: deck right effect_active 'reverb' ? blink 300ms ? color 'magenta' : off : color 'darkmagenta' now it doesn't work.
Posted Wed 01 Mar 23 @ 11:44 am
@DJElementDJ
A maybe better script for the button may be:
And your above script for the LED will work as posted.
deck right effect_active 'reverb' ? effect_stems 'vocal' off & effect_active 'reverb' off : effect_stems 'vocal' on & effect_active 'reverb' on
Posted Wed 01 Mar 23 @ 5:46 pm
or even briefer
or even briefer
get_text "`browsed_song comment``get_var string`" &
Love the scripting, and cannot get the 3rd script to append, instead it replaces, current comment with the " text I want to add".
Its the get_text "`browsed_song comment``get_var string`" that is not behaving.
Has something changed since the original post that broke it?
Posted Wed 01 Mar 23 @ 5:58 pm
no just a typo, should be get_browsed....
Posted Wed 01 Mar 23 @ 6:03 pm
yep just figured it out ... was going to post ..
Thanks Locodog !
Love all your clever ideas !
Thanks Locodog !
Posted Wed 01 Mar 23 @ 6:05 pm
Maybe even shorter version:
saves setting a var.
get_text "`get_browsed_song comment``get_text ' text I want to add'`" &
Posted Wed 01 Mar 23 @ 6:26 pm
yeah thought of that, but wanted to include the idea "grabbed data" if you're wanting to do something like this with script then likely it will be dynamic strings.
Also it would be shorter than what you wrote :P
get_text "`get_browsed_song comment` text I want to add" & param_cast & browsed_song comment
Posted Wed 01 Mar 23 @ 6:32 pm
Love it
thank you Locodog ... smiles
Posted Wed 01 Mar 23 @ 6:37 pm
Hello Everyone, I am in need of help. I have been playing with variables, and scripts, and I can't figure this out. I need a script for VDJ (Most current version), and my RANE ONE. I would like to reprogram my "TAP" Button to do this.
FX_TAP
When Pressed > Crossfader Curve Fast & Crossfader Hamster, & Key Lock Off & Blink Active
When Pressed again > Crossfader Curve 50%, Crossfader Disable, & Key Lock On
This is what I have now. It works, but not as I want it.
key_lock & crossfader_disable & crossfader_curve "scratch" ? blink : on
FX_TAP
Posted Mon 06 Mar 23 @ 7:01 pm
crossfader_disable ? crossfader_hamster on & key_lock off & crossfader_disable off : key_lock on & crossfader_disable on
something like that?
Posted Mon 06 Mar 23 @ 7:29 pm
