Topic: Script School - Page: 33.65
locodog wrote :
After bring it up to date
down ?
on & set 'VoxFXcount' `var 'VoxFXcount' ?
get_var "VoxFXcount" & param_add 1 : get_text '1' & param_cast val` & set 'voxLoopCycle' 0 & effect_stems 'vocal' on & repeat_stop 'voxRoller2' & quantize_loop on & padfx 'loop roll' 0.9 0.75 & wait 1bt 1 & repeat_start 'voxRoller' 1bt & effect_slider 'loop roll' 2 -20% & cycle 'voxLoopCounter' 2 & var 'voxLoopCounter' 0 ?
repeat_stop 'voxRoller'& repeat_start 'voxRoller2' 1bt & effect_slider 'loop roll' 1 -15% & cycle 'voxLoopCycle' 6 & var 'voxLoopCycle' 0 ?
repeat_stop 'voxRoller2' :
nothing :
nothing :
off & repeat_stop 'voxRoller2' & effect_active 'loop roll' off & get_var "VoxFXcount" & param_equal 1 ?
effect_stems 'vocal' off & set 'VoxFXcount' `get_var "VoxFXcount" & param_add -1` :
then change down query to a var query and include 2 toggles of the var
var voiceThing 0 ?
on & toggle voiceThing & set 'VoxFXcount' `var 'VoxFXcount' ?
nothing :
nothing :
off & toggle voiceThing & repeat_stop 'voxRoller2' & effect_active 'loop roll' off & get_var "VoxFXcount" & param_equal 1 ?
effect_stems 'vocal' off & set 'VoxFXcount' `get_var "VoxFXcount" & param_add -1` : set 'VoxFXcount' `get_var "VoxFXcount" & param_add -1`
I'm going to have to start charging for this
Thank you for your help again. I will input it and give you feedback. As for charging for it, please check your dm. i am willing to offer something for your help always. I just don't have paypal. If you happen to get another means where i can support,please let me know. Thanks
Here a little Script to add a manually input Dialog for set Pitch to a specific BPM Value. :)
set set_bpm `get_bpm` & set_var_dialog set_bpm BPM &
repeat_start 'bpm_change' 250ms 240 &
param_equal '`get_var set_bpm`' '`get_bpm`' ? nothing :
get_var set_bpm & param_cast 'beats' & pitch & repeat_stop 'bpm_change'
@DennYo Beats nice, I really like set_var_dialog from a makers perspective.
it's like a little command line
the part the calls the dialog is just waiting for the var change, all the user has to do is press the button and the dialog can give hand holding instructions
Hey Script-Pros,
is it possible to have "controllerTakeoverMode"="gradual" for gain knob only. Is it possible to read the controller knob position of a knob or slider using VDJ script, when it isn't synchronous with the software position. All the scripts seam to report the software-position.
Thx in advance!
Cheers
Jochen
@EGR if every dial command changed the setting and changed back, maybe.
setting controllerTakeoverMode "instant" & level & setting controllerTakeoverMode "gradual"
@LOCODOG,
that is a very good idea and may do the trick. Will check it in the evening, when I'm back home.
I said it may times and have to do it again.
This community is awesome. Thx a lot for your quick and helpful answers!
Cheers
Jochen
Hey LocoDog,
checkt your idea and it worked! Thx a lot!
Everything is on "pickup" except gain:
setting controllerTakeoverMode "gradual" & gain & setting controllerTakeoverMode "pickup"
Cheers
Jochen
How to add strings [append a tag example]
set_var string " text I want to add" &
set temp `param_add 'get_var string' 'get_browsed_song comment'` &
get_var temp & param_cast 'text' & browsed_song "comment"
quick one, save the text I want to add,
set a temp var, adding the thing I want to add to the thing I want to add to
grab the var, cast it as text, cast it to the thing I want to change
or even briefer
get_text "`param_add 'get_var string' 'get_browsed_song comment'`" &
param_cast & browsed_song comment
even briefer still, and in the order that doesn't hurt my primitive brain
get_text "`get_browsed_song comment``get_var string`" &
Without a variable
get_text "`get_browsed_song comment` myTextToAdd" & param_cast & browsed_song comment
locodog wrote :
How to add strings [append a tag example] ....
Thats a very usefull script... Thanks for sharing ... i love it. <3
Hey everybody,
I try to create a day-theme for the Prime GO.
Everythings looks great except the bowser list.
How can I change the colors of the browser list?
Here are the elements the default theme is using:
<define class="primebrowser">
<font fontsize="24"/>
<fontheader fontsize="22"/>
<fontsearch fontsize="16"/>
</define>
<filelist class="primebrowser" headerheight="[LINEHEIGHT]" lineheight="[LINEHEIGHT]">
<pos x="+0" y="+50"/>
<size width="[BRWIDTH]" height="[BRHEIGHT]-50"/>
</filelist>
How can I change colors in the design-tag?
Thx Jochen
@EGR a question better suited for the skins forum.
Electronic Green Room wrote :
Hey everybody,
I try to create a day-theme for the Prime GO. ....
add in the <define class="primebrowser"...> the COLOR children.
https://www.virtualdj.com/wiki/Skin%20Browser.html
When you need mor help please post in the Skin Forum.
hello, help me assign a button so that when you turn it on, the effect 'reverb' and stems fx 'vocal' are activated, and when you press the button again, the effect 'reverb' and stems fx 'vocal' disconnected.
something like this, but it doesn't work: deck right effect_active 'reverb' & effect_stems 'vocal' on : effect_stems off
happened!!! it works: deck right effect_active 'reverb' ? effect_stems 'vocal' on : effect_stems off
now the question is how to register so that the button blinks when the effect is on and burns when it is off?
I used to have this: deck right effect_active 'reverb' ? blink 300ms ? color 'magenta' : off : color 'darkmagenta' now it doesn't work.
@DJElementDJ
A maybe better script for the button may be:
deck right effect_active 'reverb' ? effect_stems 'vocal' off & effect_active 'reverb' off : effect_stems 'vocal' on & effect_active 'reverb' on
And your above script for the LED will work as posted.
or even briefer
get_text "`browsed_song comment``get_var string`" &
Love the scripting, and cannot get the 3rd script to append, instead it replaces, current comment with the " text I want to add".
Its the get_text "`browsed_song comment``get_var string`" that is not behaving.
Has something changed since the original post that broke it?
no just a typo, should be get_browsed....
yep just figured it out ... was going to post ..
Thanks Locodog !
Love all your clever ideas !
Maybe even shorter version:
get_text "`get_browsed_song comment``get_text ' text I want to add'`" &
saves setting a var.
yeah thought of that, but wanted to include the idea "grabbed data" if you're wanting to do something like this with script then likely it will be dynamic strings.
Also it would be shorter than what you wrote :P
get_text "`get_browsed_song comment` text I want to add" & param_cast & browsed_song comment
62%
