Topic: Script School - Page: 31.65
Cool
I've updated the script linked in the video
Hi
I have always used the "comment" field for remix info because originally VDJ didn't have a 'remix' field to use & I was happy to continue in that vein, however now I am using online content I need the remix field visible.
I have worked out that
browsed_song 'remix' `get_browsed_song 'comment'`
will successfully copy the comment over to the remix field but this only works 1 file at a time.
Is there a quick way I can change, either selected files or all files in a folder, in 1 go.
Basically I need a script to recurse through the list of files & copy the comment field to the remix field.
Any pointers would be appreciated. If this has been covered elsewhere I apologise.
Thanks
That would be a repeat_start script [a.k.a. rsi, repeat_start_instant]
probably best if you start out of a filter [advanced] to get all files, something like
filter
Length > 60 and Comment is not ""
button script
browser_scroll 'top' & repeat_start_instant scroller 25ms & browsed_song 'remix' `get_browsed_song 'comment'` & browser_scroll 'bottom' ? repeat_stop scroller : browser_scroll +1
or this to also clear the comment field after it copies over
browser_scroll 'top' & repeat_start_instant scroller 25ms & browsed_song 'remix' `get_browsed_song 'comment'` & browsed_song 'comment' "" & browser_scroll 'bottom' ? repeat_stop scroller : browser_scroll +1
either will take a little while, it processes about 2000 tracks a minute
There are some people saying it just stays on COUNTDOWN when they try the script
Not sure why...
Found it, 12 hour clock users. I'll make the changes needed, and post here when changed
*edit changed*
Hi, is there a simpler way to create save Stems with a custom Button.
The Stems should be save from the loaded Song in the deck and not from the browser.
browser_window 'songs' & wait 150ms & search_add `deck left get_filepath` & browser_scroll +1 & browser_scroll -1 & wait 150ms & virtualfolder_add 'stems' & wait 150ms & search_delete & goto_last_folder
The second. Is there a way to visible "has prepared Stems" like Browser Color Rules, for the loaded Song?
has_stems "2.0"
isn't a filter yet, but they are all filtered in the the prep'd folder.
not sure about adding.
has_stems '2.0' is always true when RealtimeSeperation enabled.
I need a true when a prepared stem is saved.
how to assign a button so that when it is activated, the filter works as filter_selectcolorfx 'pitch', but only for voice?
effect_stems 'vocal' on ? effect_stems 'vocal' off : effect_stems 'vocal' on & filter_selectcolorfx 'pitch'
something like that
If you are asking if it is possible to change/set a color for tracks, that have prepared stems?
This can be done with a color rule: Prepared Stems = 1
button script
Thanks for that. I figured to either us a filter or just smaller folders to make it easier, also going to disable automatic writing of mp3 tags before hand otherwise my backups will take forever.
I'm still trying to get my head around repeat from your previous lessons but this example seems really straight forward and easy to understand & edit if I needed something similar.
PS. also added ' browser_window "songs" & ' to the beginning of the script cause I will forget to click in the songs windows 1st due to being hopeless.
Hi.
We decided here whether the script can count the number of characters in the string.
It took me a while, but I understood him.
param_equal `get_var a` `get_var a & param_cast 'text' 1` ? SIZE OF 1 :
param_equal `get_var a` `get_var a & param_cast 'text' 2` ? SIZE OF 2 : ......
Can the script be modified to detect if the string is longer, shorter than 25 characters? Nothing comes to my mind.
edit
Can't write in a shorter script?
set_var 'a' "12345678901234567890123456" &
(param_equal `get_var a` `get_var a & param_cast 'text' 1` ? set 'length' 1 :
param_equal `get_var a` `get_var a & param_cast 'text' 2` ? set 'length' 2 :
param_equal `get_var a` `get_var a & param_cast 'text' 3` ? set 'length' 3 :
param_equal `get_var a` `get_var a & param_cast 'text' 4` ? set 'length' 4 :
param_equal `get_var a` `get_var a & param_cast 'text' 5` ? set 'length' 5 :
param_equal `get_var a` `get_var a & param_cast 'text' 6` ? set 'length' 6 :
param_equal `get_var a` `get_var a & param_cast 'text' 7` ? set 'length' 7 :
param_equal `get_var a` `get_var a & param_cast 'text' 8` ? set 'length' 8 :
param_equal `get_var a` `get_var a & param_cast 'text' 9` ? set 'length' 9 :
param_equal `get_var a` `get_var a & param_cast 'text' 10` ? set 'length' 10 :
param_equal `get_var a` `get_var a & param_cast 'text' 11` ? set 'length' 11 :
param_equal `get_var a` `get_var a & param_cast 'text' 12` ? set 'length' 12 :
param_equal `get_var a` `get_var a & param_cast 'text' 13` ? set 'length' 13 :
param_equal `get_var a` `get_var a & param_cast 'text' 14` ? set 'length' 14 :
param_equal `get_var a` `get_var a & param_cast 'text' 15` ? set 'length' 15 :
param_equal `get_var a` `get_var a & param_cast 'text' 16` ? set 'length' 16 :
param_equal `get_var a` `get_var a & param_cast 'text' 17` ? set 'length' 17 :
param_equal `get_var a` `get_var a & param_cast 'text' 18` ? set 'length' 18 :
param_equal `get_var a` `get_var a & param_cast 'text' 19` ? set 'length' 19 :
param_equal `get_var a` `get_var a & param_cast 'text' 20` ? set 'length' 20 :
param_equal `get_var a` `get_var a & param_cast 'text' 21` ? set 'length' 21 :
param_equal `get_var a` `get_var a & param_cast 'text' 22` ? set 'length' 22 :
param_equal `get_var a` `get_var a & param_cast 'text' 23` ? set 'length' 23 :
param_equal `get_var a` `get_var a & param_cast 'text' 24` ? set 'length' 24 :
param_equal `get_var a` `get_var a & param_cast 'text' 25` ? set 'length' 25 :
set 'length' 26) &
var_smaller 'length' 25 ? set_var 'copmp' "smaller" :
var_equal 'length' 25 ? set_var 'copmp' "equal" :
var_greater 'length' 25 ? set_var 'copmp' "greater"
start at 24 if thats all you need.
Yes. You are right to use the property "24". Thanks
param_equal `get_var a` `get_var a & param_cast 'text' 24` ? set_var 'comp' "smaller" :
param_equal `get_var a` `get_var a & param_cast 'text' 25` ? set_var 'comp' "equal" :
set_var 'comp' "greater"
Is there a script that would let me continue my track playing from the point that a loop started at when exiting, instead of continuing from the end of the loop. I would like to jump back to the point the loop started and go from there. why I hear you ask.
so if I have a track that has no decent intro to mix with, I could loop the first 1 or 2 bars and use stems to remove the vocals and melody, to get just a rhythm loop, and then exit the loop and re-enable the vocal and melody stems and jump back to the start point of the now exited loop and continue playing the track with the full vocal and melody.
hope that made sense.
M.
reloop & loop off
so is there now a way of waiting till the end of the current loop before doing the reloop. for example if i press the button to do this and the current loop is on beat 3 for example, I dont want it to reloop immediately, but wait until it is at the end of the current loop and is about to restart the loop.
so far I have
var $intromode 1 ? reloop & only_stem "melody" & only_stem "vocal" & loop off & set $intromode 0 : loop 4 & mute_stem "Melody" & mute_stem "vocal" & set $intromode 1
if waiting for end of loop to reloop, just let it loop and not use reloop. Use a rsi to monitor and save inLoop position, if current is smaller than saved then the loop has just restarted and your switches can be reset.
Locodog.. wouldn't this be a great use for your RoutineSP addon?
https://www.virtualdj.com/forums/233820/Addons/routineSP.html?search=routinesp&page=1
Update: Opps.... I see needs vocal stems removed and added back. Then may not be best use
Or could use RoutineSP and only need to do the stems manipulation.
59%
