Topic: Script School - Page: 22.2
since the stock echo isnt a good echo I need a script that i can assign to a button that activates a solo vocal stem, then turns on BFX-Echo and the stock echo. The BFX-Echo should turn off after the timing set in the BFX-Echo settings with the stock echo acting as it normally does.
What have you tried?
I got the echo part deck left effect echo active
So tried not much. [given you just copied v7 script from your controller]
stem solo you've been shown recently [search stem in the mapping window if you can't remember], the fx(s) active you know [but v8 syntax is effect_active "Name" ] the only thing that isn't straight forward is the fx off timing by an fx setting, that will be a list of queries against the fx buttons, when true start a single repeat_start with a bt for the time parameter
....effect_button "BFX-Echo" 1 ? repeat_start 'NAME' 0.125bt 1 & TURN BFX OFF : QUERY SECOND BUTTON etc
I can't see this being what you're after bfx doesn't trail on stop, so bt being same as fx, you're just feeding the stock echo with extra steps.
actually Im feeding the stock echoe the the echo i like which makes the bfx echo the echo trails the made by the stock echo. giving me the volume of the echoe that I need when transitioning or even with just using the echoe during the song.
locodog wrote :
like this
browser_open_folder & browser_open_folder ? : browser_enter
thanks! but isn't completely what i would, because after opened a folder with subfolder. focus is in browser_window 'songs' and not only open a folder with subfolder, bit if focus is in subfolder....yes it can move to browser_window 'songs'
Not an easy script, I don't know how you get me for the money.
set '$tab' `get_browsed_folder_tab` & browser_open_folder & repeat_start 'name1' 50ms 1 & browser_scroll +1 & param_equal `get_browsed_folder_tab` `get_var '$tab'` ? browser_scroll -1 & browser_enter : param_bigger `get_browsed_folder_tab` `get_var '$tab'` ? browser_scroll -1 & browser_enter : browser_scroll -1
I used to think I was fairly intelligent until I came across vdj script. Now I feel dyslexic.... I just dont get it and whenever I try I destroy my mapping. I give you guys a lot of credit and respect cause I just dont get it.
@xxx
make a make backups and give it a go, it's a language some people aren't wired for that [I'm not], consider this thread and the verb list a phrase book & dictionary, to actually learn you have to use the language. Even if it's trivial simple stuff, keep repeating it until you can't forget it. Eventually when a few concepts have burnt in the verb list stops appearing vague, it appears concise.
thanks a lot my friend...I took a idea from your script and i have now my solution!
browser_window 'folders' ? param_equal `browser_open_folder` `on` ? browser_window +1 : get_browsed_folder_tab & param_bigger 1 ? browser_window +1 : browser_open_folder 'on' : browser_window +1
cool if that works, [your tree must be structured a specific way]
Hello @locodog.
i have a serious problem with my Akai APC mini with the sampler and i've tried for months to resolve this but i'm really out of ideas, and i really need help.
So, VDJ is unable to keep in memory the volume of each slider and each time I open vdj the volume of the sliders (except master slider) is at 100% .... result, i have to push the slider up and down to be able to manipulate the volume correctly (I have already tried various manipulations with volume scripts without success).
Normally there's a script which signal to the software that's my controller which impose the position of the sampler volume and not the basic script from the software.
There are very specifics terms to use to say that it is the position of the fader on the controller which impose the position of the adjustment on the software but frankly i cannot find them.
Please @locodog i really need help to use correctly my APC mini during my sets.
Regards, Aku.
sampler isn't designed to be used that way.
You should set your sample gains so that they are perfect for being played solo with level slider fully open. As you play more samples attenuate with group volumes or sample master volume.
Years back I made a plugin that remembered and recalled group volumes but it was limited to the sample bank visible, and really wasn't the right way of going about it.
mg_1978 wrote :
Nicotux wrote :
[quote=Svenino]Want a button with two functions:
1. short press: start and stop the sampler (sample_pad 1)
2. long hold: Set a "Var" for volume change of this sampler without starting or stoping it.
(Holding this button is like a shift, so that a slider can control the volume of this sampler, but just as long You are holding the button)
After a looong time fighting with VDJScript here is a working one:
deck master up ? set '$s1v' 0 & repeat_start myrep ? sampler_play_stop 1 & repeat_stop myrep : : repeat_start myrep 200ms 1 & set '$s1v' 1
tested deck master to try to sync sampler_play_stop
if not , free to use sampler_pad instead
hi! this is very wonder script šŸ‘šŸ‘šŸ‘šŸ‘šŸ‘ thanks
hi! i have this question:
i’m in folder ā€˜Sampler\Recordings’ and focus in browser_window ā€˜songs’ (i see samples file .vdj that i have recorded)…if i use script for ddj-rzx monitor:
get_browsed_song ā€˜title’ i can see file name in play at this moment (and focused), but if when sample is in play i scroll focus in browser_window ā€˜songs’ this name change, because i scroll the ā€˜title’ focused, i think, is there a script for see only sample in play at this moment in browser_window ā€˜songs’, despite i scroll files (i change focus position)?
thanks a lot
mg_1978 wrote :
[quote=mg_1978][quote=Nicotux][quote=Svenino]Want a button with two functions:
why with script: sampler_pad 1 ā€˜auto’ (pad 1-8) instead sampler_play_stop 1 it doesn’t work??
thanks
hi! i use this script for change some parameters about samples:
but if i change sampler_play_stop with sampler_pad ā€˜auto’ it doesn’t work, why?
is important (for me) change in sampler_pad ā€˜auto’ because in banks with more 8 samples in rightdeck controller decks (2-4), if i push pad 1 i would listen sample 9…i listen sample 1 instead :(
Hello locodog.
I really think it's the next improvement to add in VDj sampler.
So do you have a link for this plugin? Maybe i can do something with it.
thank, Aku.
No I won't be sharing it, like I said it isn't the right way to go about it.
I only made it for the challenge of making it.
Hello Locodog.
Well that really a flaw in virtual, mean what the purpose to have a external sampler if you cannot use or map the slider like you want?
This a kind of parameter MUST BE available in vdj...Sorry for my frustration but i ear you about a possible script (technically it perfectly works) and see atomix do nothing on this implement....Holly shoot!!!
regards, Aku.
42%
