Question:
With 1 button: press and switch on sampler effect and press again then switch off sampler effect.
ej: effect_active sampler 'echo' ? effect_active sampler 'echo' on & effect_active sampler 'echo' off
It does not work.
It does not work.
Posted Wed 27 Jan 21 @ 1:28 pm
          replies wrong way round, [*edit* your script hasn't an false reply to the query]
is SOMETHING on ? [yes it is] turn it off : [no it isn't] turn it on
the : is important.
your script as is, is asking
is SOMETHING ON ? [yes] turn it on AND turn it off [that's it, you don't give a no reply
the : is important.
Posted Wed 27 Jan 21 @ 1:29 pm
          So?
effect_active sampler 'echo' on ? effect_active sampler 'echo' off : effect_active sampler 'echo' on
the : is important.
the : is important.
Posted Wed 27 Jan 21 @ 1:34 pm
          in the absolute yes
but the verb effect_active is a toggle action
is enough
is enough
Posted Wed 27 Jan 21 @ 1:43 pm
          Thanks Nicotux.
    Nicotux wrote :
in the absolute yes
is enough
is enough
Posted Wed 27 Jan 21 @ 2:09 pm
          Thanks Locodog
the : is important.
the : is important.
Posted Wed 27 Jan 21 @ 2:10 pm
          Hey ! I am triing step sequencer pad...BUt I already have a problem. For the get_beat_num division no problem but how to divide beat in 2 or 4 ?  or maybe in triplet...? thanks in advance :-)
    Posted Mon 01 Feb 21 @ 11:29 am
          get_beat_bar 1
    Posted Mon 01 Feb 21 @ 12:40 pm
          Hi, does anyone know how to do the Richie Hawtin effect with the Virtual dj effects?
In Traktor it uses the tape delay capturing the sound and playing with the tonality.
But in Virtual dj we do not have the tape delay effect or the parameters that it has in the virtual dj delay.
Any suggestion?
Any suggestion?
Posted Fri 05 Feb 21 @ 10:37 pm
          VDJ is a VST host....
https://ask.audio/articles/how-to-create-a-richie-hawtin-style-delay
Posted Sat 06 Feb 21 @ 12:11 am
          Nicotux you are a god.
Thank you very much friend.
Posted Sat 06 Feb 21 @ 6:41 am
          hi at all! i have this question: i have written script: action_deck 1 ? deck 1 sampler_bank ‘recordings bank’ : action_deck 2 ? deck 2 sampler_bank ‘instruments’ : nothing
(for have in pad_page ‘sampler’ about deck 1 and 2 two different sampler bank) but don’t work :( could do this?
Posted Tue 16 Feb 21 @ 2:41 pm
          there is only one sampler and have dynamic deck assignment so that your script can't work
action_deck 1 ? sampler_bank "Recording Banks" : action_deck 2 ? sampler_bank "Instruments" : nothing
work fine but may not do what you expect
it needs to be in both decks exactly the same as
button on deck 1: sampler_bank "Recording Banks"
button on deck 2: sampler_bank "Instruments"
maybe you better want
working depending on selected deck:
deck default get_deck 1 ? sampler_bank "Recording Banks" : get_deck 2 ? sampler_bank "Instruments" : nothing
or
working depending on the deck with higher level:
deck active get_deck 1 ? sampler_bank "Recording Banks" : get_deck 2 ? sampler_bank "Instruments" : nothing
or better a switchable repeat script doing it for you ?
repeat_start swsmp ? repeat_stop swsmp : repeat_start swsmp 48ms -1 & deck active get_deck 1 ? sampler_bank "Recording Banks" : get_deck 2 ? sampler_bank "Instruments" :
or
Posted Tue 16 Feb 21 @ 3:33 pm
          Quick question:
Why does
deck left play ? color 'green' : color 'green' & blink
NOT cause a launchpad LED to blink, when the left deck is not playing? (above is the mapping for the LED, not the pad action)
The pad is green, just does not blink.
    Why does
Posted Tue 16 Feb 21 @ 8:36 pm
          because blink is a query which is on or off depending on time
use
deck left play ? color green : blink ? color green
you may also use two colors
deck left play ? color green : blink ? color green : color darkgreen
    use
Posted Tue 16 Feb 21 @ 9:01 pm
          @nicotux : doesn't work :(
    Posted Tue 16 Feb 21 @ 9:37 pm
          use with a controller may differ specially with colors some have specific colors only
launchpad X mapping is recent and as said in the other thread update is coming
the above script is for use (and working) with skin pads
(in color tab) which mostly is the same as LED (depending on controller)
Posted Tue 16 Feb 21 @ 10:02 pm
          Thank you  Nicotux
Your solution worked perfectly..
Again Big Thanks
PS
and it was. MG_1978 that said it does not work,........and he never said what the script was for..
I believe everything works well with Launchpad X, the native definition did not also include the capability to utilize its Velocity touch features, and that is being added.
use
use
Again Big Thanks
PS
Posted Wed 17 Feb 21 @ 4:47 am
          That's the problem with multiple questions when tired :=)
sorry mg_1978 i answered the wrong post
as said you can't actually get 2 different samplers banks at a time because only one sampler exist
when selected both side sampler pads are linked to the sampler (always same bank)
i provided 3 scripts examples switching manually sample bank and one auto
which one doesn't work ? All?
They actually all work as expected here, so that maybe as IIDEEJAYII pointed out more explanation about what you are trying to achieve is needed
I agree showing different sample bank pages even not selected and switching on the fly would be nice
the same for pads : a way to display all 4 pages of selected padpage would be fine
Posted Wed 17 Feb 21 @ 8:10 am
          sorry! i have written ‘doesn’t work’ for Nicotux answer about my sampler question; your script (@Nicotux) yes works well for change sampler_bank....but not for my question; i would change 2 different sampler_bank about 2 decks, but i have understand that is NO possible in Virtual Dj (in Traktor Pro for example you can have one different bank in different deck....but is not Virtual Dj teory).... tanks a lot at all and this is a very 👍 forum
    Posted Wed 17 Feb 21 @ 2:55 pm
