Hi, I'm currently solving problems with latency/lagging of sound when playing from VDJ8. I already have made some steps to turn off some problematic services and now situation is better, but still not ok.
I'm using LatencyMon and also utility from NativeInstruments for measuring latency and diagnostics and I found weird thing - each of them are reporting different numbers.
Anyone faced this also? Any idea what are the correct numbers?
see details - https://www.dropbox.com/s/3c5sn793c9o5ph3/Bez%20n%C3%A1zvu.png?dl=0
Dell XPS 13 (9360) - Intel(R) Core(TM) i5-7200U CPU @ 2.50GHz, 8GB RAM, 256 GB M.2 SDD, Win 10 home
Thanks
Zdenek
Thanks
Zdenek
Posted Fri 02 Feb 18 @ 7:49 am
DPC Latency etc... is mostly to check for problems concerning dropouts.
The maximum there is about 3ms, so that should not be much of a problem if running your sound card at around 10ms (512 samples)
If you have lag problems, you should check your vdj audio config, and the asio latency settings of your sound card.
Posted Fri 02 Feb 18 @ 2:55 pm
