Topic: PLAYLIST AND SKIN ISSUES
magic11ControlleristMember since 2017
I just purchased a Pioneer DDJ SX2 controller and the license for this unit. I installed VDJ8 on my windows computer and the controller is working perfect with the following exceptions. The skin always reverts back to the default skin and when I save playlists, they are nowhere to be found in the computer. Is this a limitation of the one license / controller? What is the solution? Would VDJ8 Pro make a difference with these features? Thanks for your help.
Posted Sun 14 Jan 18 @ 7:56 pm
Sounds like your user> Documents> VirtualDJ folder doesn't have correct permissions. check it's not set to read only.
Posted Sun 14 Jan 18 @ 8:00 pm
