Hi everyone,
b4742 has the same issue again. Any guess?
I'm using MBP 2018 with 16gb RAM and always need to close the program to solve.
Thanks in advance.
Juan
Thanks in advance.
Juan
Posted Thu 14 Feb 19 @ 2:56 pm
I never experimented this one until right now
I block rename 8 files 7 mp4 and 1 .avi, no name conflict possible, none loaded, when VDJ stop responding
What is strange is there is no dialog "Program stop responding" in that case. It seems going on working. After a look to folder, All files have been rename correctly
VDJ have done the job but does not consider it as terminated
Posted Fri 15 Feb 19 @ 9:56 pm
The latest build is 4756. It is an early access update*.
Maybe this problem is fixed in this version, because there have been some changes in the browser as far as I know.
If you want to try this build you have to enable "earlyAccessUpdates" in your config's options.
*Mind that early access builds are something like "beta updates" or like "updates that are kind of experimental"...
If you experience problems with an early access build turn off "earlyAccessUpdates" in your config's options and over-install an previous and stable working public build from:
http://www.virtualdj.com/download/build.html
Posted Sat 16 Feb 19 @ 11:55 am
In fact I was Wrong, VDJ rea
Posted Sat 16 Feb 19 @ 1:14 pm
