Topic: deezer
hi all I use deezer on vdj8 at home so the little lad can have a play about on it but its came up with you need a premium + account whitch I have cause I pay 9.99 a month for it. this is the second time its happened now the first time it just cleared. any body had the same issue. thatnks chris
Posted Sun 14 Jan 18 @ 10:47 am
Having the same problem. Tired logging out and in and restarting VDJ multiple times. Open for suggestions.
Edit:
Found the solution (at least for me). Deezer only allows for one device to play music at a time. So if you have Deezer open in your browser or the mobile app, it won't play. After I closed my browser window it worked.
Deezer works not with VDJ 8 when you have the 30 Testdays not End.
You cant log in in Deezer.
After the Testdays the Deezer Premium + should Work fine.
Greetings,Dirk
how to connect my deezer account to my virtual dj 7
You can't it's VDJ 8 only
Deezer is in VDJ 8, not VDJ 7. Also it's for home use only.
