how do i fix this
as need fix asap as i use the cue to get to point on other track for mixing
Posted Tue 02 Jan 18 @ 2:09 pm
found a way around it
Posted Tue 02 Jan 18 @ 2:21 pm
The "booth" output is optional i guess, you just need the "Master" & "Headphones". That's the default/pre-defined audio configuration which is also generated by the special "Pioneer DDJ-SB2" button at the top, as per the manual http://www.virtualdj.com/manuals/hardware/pioneer/ddjsb2/installation.html
http://www.virtualdj.com/image/big/70495/197450/AudioSetup.png
Posted Tue 02 Jan 18 @ 3:51 pm
