Hi everyone my name is Lawrie gee and my problem is sound , when playing out at one my venues my system plays great then at any random point in the night it just stops output of sound the vdj says its still working all the settings look correct but only have headphones could be issue on soundcard in pc ? running numark platinum with computer on win7 with 5.6 operating platform only vdj onboard rest on external drive
external drive runs on a 3 port and controller on a 2 port just totally baffled have changed controller to see if was output board but is better but still not right please help before get sack thanks to you all
Posted Sun 17 Dec 17 @ 11:29 am
Check and make sure no effects are still active your master volume is still open I had the same issue couple days ago I fixed it simple by switching my output master to headphone and back but try check the first steps first
Posted Sun 17 Dec 17 @ 2:39 pm
Wink 0012, you can't compare your issue with his because, you have a Pro version and we have no idea which version he is using. I would suggest that since you are worried about "getting sacked" at this venue, you buy a version that allows you to play out in public. You are listed as a home user, which does not have all of the features that you need to use a controller, and is not supposed to be used in public.
Posted Sun 17 Dec 17 @ 7:08 pm
Just trying to help
Posted Wed 10 Jan 18 @ 11:28 pm
