Topic: I need help configing the settings
I use 8.2. I have a folder of 900 songs, but I can't find a setting to play all of them one after another? I searched for a solutions, played around with the settings, but nothing works.
Also, if the problem is fixed, is there a way to remove the silences in real time while playing and make the next song fade in the one playing at the end?
Thank you!
Posted Mon 11 Dec 17 @ 12:20 pm
Thank you!
Yes, you probably need the automix function
Take a look at this video:
Posted Mon 11 Dec 17 @ 12:43 pm
Thank you!
Also, is there a way to shuffle the songs in the automix in real time?
Posted Tue 12 Dec 17 @ 10:11 am
Yes:
But I always use the "shuffle once" option.
That shuffles the songs, but let me still see their play time
Posted Tue 12 Dec 17 @ 10:48 am
