Topic: VirtualDJ controller license - Page: 2
locodogPRO InfinityModeratorMember since 2013
Your audioConfig might be wrong, show us a picture
Posted Sat 14 Sep 19 @ 4:52 pm
Posted Sat 14 Sep 19 @ 9:05 pm
try removing the line input :-)
Posted Sat 14 Sep 19 @ 9:21 pm
You probably want this, or the wasapi equivalent.
Posted Sat 14 Sep 19 @ 9:40 pm
That was the original state, and did not work.
I first thought the Hercules could be considered to be input...
Posted Sun 15 Sep 19 @ 7:44 am
I guess that this is indeed what I want.
I assume I need to take some action somewhere to have the Hercules Control Steel added to the "card" section...
I will try to keep on looking for a solution, but thanks for any tips and suggestions.
Posted Sun 15 Sep 19 @ 7:50 am
Posted Sun 15 Sep 19 @ 8:24 am
The Steel has no audio interface, inputs or outputs, so will not appear in the 'card' section of VDJ.
Posted Sun 15 Sep 19 @ 8:27 am
locodog wrote :
I noticed that for some reason my drivers were not properly installed.
Because I got no notification during/after install yesterday, I did not pay attention (tunnel vision, as you assume that step is correct)
So just uninstalled it, and installed it again, and it is working now.
Thanks all for the support.
where did I get P8 from? *kicks at floor, falls over*
Posted Sun 15 Sep 19 @ 10:04 am
मुझे नया लाइसेंस बनाना है
Posted Fri 05 Mar 21 @ 2:27 pm
Posted Fri 05 Mar 21 @ 2:30 pm
i need Licenses for numark please help me
Posted Sun 25 Jul 21 @ 4:14 pm
I need help with license
Posted Wed 16 Nov 22 @ 6:27 am
gabycorreaPRO InfinityModeratorMember since 2010
Posted Wed 16 Nov 22 @ 6:24 pm
