Topic: 5760x1080 UI Problem
Hello, Community I have just installed VDJ 8.2 when I open the Client the software opens full screen and does not fit I have tried to move the window so as to pick a side and resize it but I can not get it to move in any way except to close the Application. I have tried Many skins with no change to the size or dimension of the Application window, Is there any way I can resize it to just open at 1920x180. Many thanks in Advance.
Posted Mon 02 Oct 17 @ 11:39 am
Ok, so I have a workaround just disable the ATI Eyefinity Mode and run it as 3x1920x1080.
Posted Tue 03 Oct 17 @ 4:53 pm
