Won't keep setting's when turn off and back on ???
Posted Sun 03 Sep 17 @ 6:19 pm
Which settings? Maybe whatever you're changing is not something that gets saved.
Which version of VDJ 7 are you using? What's your computer (Mac or PC)? What's your operating system?
Using a controller? Which one? Details!
Posted Sun 03 Sep 17 @ 6:36 pm
figured that one out, now on virtualdj 8, when I try to log on to ur site it says: cannot connect to virtualdj servers ???
Posted Sun 03 Sep 17 @ 8:15 pm
I'm running windows 10
Posted Sun 03 Sep 17 @ 8:16 pm
yes I have internet cause I can connect to other sites but not urs
Posted Sun 03 Sep 17 @ 8:18 pm
Sounds to me as if you've had a cracked copy on your computer at some point.
Download the cleanup tool and try again https://virtualdj.com/plugins/?addonid=80191
Posted Sun 03 Sep 17 @ 8:34 pm
tried it & still doesn't let me log in. Its a used pc that I just bought, wat could it b ???
Posted Sun 03 Sep 17 @ 9:41 pm
