Topic: Problems Uploading iTunes library?
Hi,
Ive just downloaded the software and having problems uploading iTunes library to Virtual DJ?
I think the problem is that most of it is from Apple Music and wasn't downloaded to the computer when I installed it, but even since I've downloaded things they won't appear on the iTunes library on the Virtual DJ interface? Is there a way to import music directly from iTunes?
Posted Sat 12 Aug 17 @ 10:23 am
Apple Music tracks are DRM copy protected because it's a rental service, so they won't play in VDJ.
With a Pro license you do get the option of using Spotify, Deezer, Groove (streaming) and Pulselocker (stream or download) though, so plenty of choice.
