I've just finished (after 2 months, every evening till late at night) analyzing 9000+ tracks (coming from Traktor, so had to edit (cue points, loops, beatgrid) all my tracks again)). I'm now on VDJ 8.2 build 3798 (last update from several days ago).
Now I notice when I load a track in a player, VDJ seems to automatic analyze (set/adjust beatgrid) the track again (all tough it was already analyzed, cue points set, BPM grid set (with red marker set in BPM editor)). Hereby, in some cases, my settings are being moved and 'redone' by VDJ.
I'm not amused ... !
Is there a way to prevent VDJ from automatic analyzing (redoing beat grid), so all my settings (cue points, firts beat marker (Beat Editor), saved loops) stay as I put them ?
I don't want 2 months of work wasted by VDJ because 'the beat analyzer has been updated' ...
And yes, I have 'ExperimentalBeatAnanlyzer' set to NO in the Options.
Posted Mon 24 Jul 17 @ 8:55 pm
You can't avoid it.
VDJ was updated with a revised analyzer and they decided to force a rescan of each track when played or loaded in the Automix panel. Not quite sure why as there have been a lot of people asking about this. Personally I think the rescan should have been an option but hey ho.
Apparently if you have manual beatgrid settings they do not get changed when the tracks are reanalyzed.
Posted Mon 24 Jul 17 @ 8:59 pm
Whats the point in (re)analyzing already analyzed tracks on load ????
I think it's pretty simple to add an option in the Options menu by the programmers to 'Re-Analyze tracks on load YES / NO'
This track (picture) was manually beat grid and still VDJ moved (re-analyzed) the First Beat Marker (red line) a few millimeter on load, making the beat grid slightly off-beat and thereby the Saved Loop in the track is also no longer accurate and also slightly off.
Manually set:
After re-analyzing (just by loading track in a deck):
2 months manual work down the drain ????
Manually set:
Posted Mon 24 Jul 17 @ 9:35 pm
I'm sure the devs will chime in. They definitely said that manual adjustments will not be modified with the new analyzer so I can't explain that one.
Posted Mon 24 Jul 17 @ 9:38 pm
'Options menu by the programmers to 'Re-Analyze tracks on load YES / NO' "
Posted Tue 25 Jul 17 @ 12:10 am
Manually modified grids should indeed not be modified.
How do you usually modify the grid?
Also, which track did you use in the screenshot?
Posted Tue 25 Jul 17 @ 3:25 am
It is a random track from my collection (club music). A current club-track, so with a steady beat(grid). I have manually edit all my club tracks (with metronome ON) like in the first screenshot. Now, after VDJ automatic re-analyzing, metronome is slightly off (screenshot 2) (with is normal if you look at the position of the adjusted First Beat Marker) which also has effect on the Saved Loop (first beat of loop is also slightly off).
Here's how I modify grids:
1) I load the track in a deck (VDJ does it's automatic analyzing)
2) I open BPM Editor
3) I activate metronome, zoom in at the firs beat marker (red line) and if the metronome is off-beat (beginning from the First Beat Marker), I adjust (move) te first beat marker until metronome is on-beat.
In many cases I had to fine-tune the First Beat Marker position to be like in the first screenshot. If VDJ put the marker automatic spot-on, I did no adjust (logic, if it's good, no need to change).
So I made sure all my tracks are beat-grid (First Beat Marker set) like in screenshot 1. If VDJ didn't do it right, I adjusted it.
So in both cases the beat grid has to stay as it is.
Manually set or automatic set by VDJ.
If I didn't adjust the automatic set beat grid, that means it was good. So why redo it (and apparently adjust in some cases) a beat grid that was fine for me in the first place ?
I don't understand why VDJ does a reanalyzing of already analyzed tracks ? If a track is analyzed and you are not happy with the (beat grid) result, you manually adjust until you're satisfied. Or you CHOOSE to let VDJ reanalyze if you don't want to put effort in manual editing.
And being able to lock the beat grid when you put a lot of manual effort in finetuning is pretty essential in DJ software ...
Posted Tue 25 Jul 17 @ 12:48 pm
Read the second message again. The analysis code was updated / improved.
Posted Tue 25 Jul 17 @ 7:27 pm
To actually see the issue happening, I made this video.
Track is 'Dave Lambert - Funky town'.
And the track was already analyzed, you can see the LOAD marker (manually set by me).
These are screenshots of the before and after in BPM Editor:
BEFORE VDJ re-analyze (analyzed and edit/(re)set First Beat Marker by myself):
AFTER VDJ re-analyze (only by loading track in deck) modifying the First Beat Marker (wrong):
As you can see, VDJ automatic re-analyzed and moved the First Beat Marker (1/2 beat move forward), making the grid start (first of 4 beats measure) 1/2 beat too late.
Al tough the track was (before last software update) manually edit, LOAD marker set and First Beat Marker set on the right position, when loading the track AFTER the last software update (few days ago), VDJ re-analyzed and modified the First Beat Maker (and thereby also the beat grid), overruling my manual editing ...
Pretty nasty problem
Posted Tue 25 Jul 17 @ 9:00 pm
