Forum: Old versions
Topic: Vdj LE 7 not working after few minutes
Hey every body. I have a american audio 14 mxr that comes with vdj le 7. I installed the software and use the cd key provided so that my vdj le will not be a trial version. But i noticed that after a few minutes, even i play songs, there is no sound. Knobs and faders are working but there is no output
Posted Tue 18 Jul 17 @ 4:58 am
Please register your VDJ LE serial number (key) to your forum account, so that the forum shows you as a registered user. You can then also download the latest version from your account.
hi everyone,
I purchase a vms4.1 last week, tried to install it today but it says my 20 day trial has been used already. I can't get pass that screen to set up my audio. can anyone help. I'm using a Mac
meyotte wrote :
hi everyone,
Looking at your profile it looks like you are registered with a pro infinity license
That gives you a full use of the software with any controller, so you don't need the LE software
So in that case you should simply be able to download the latest VDJ 8 from the download section of this page, install it, and login with the same credentials as the ones you use for this forum, and be good to go
If you prefer v7 a pro infinity license should also give you access to that under "my licenses" on your profile page on this webpage
