Topic: Need Help!!!
I just bought a VMS4.1 traktor 2 from a person and can not get it to work with. Is the program download or purchused? please someone help me!?
Posted Mon 17 Jul 17 @ 2:05 am
Traktor is a competetor software to the virtual dj software, and you are currently on the virtual dj software homepage.
That being said virtual dj may be a better software for your controller. You can download it from the download pane. Your controller is plug and play with virtual dj. You only need to install the drivers for it first from the units homepage. You can then test it with virtual dj for 10 min at the time for free, and buy a license if you want to continue using virtual dj
