Topic: Build 3780 Headphone issue [b]SOLVED with lesson[/b]
Running Mac with 3780 & i have never had this issue. I have 2 controllers, currently for a bar i am using a Hercules RMX2 and i just updated to 3780 and i hear dead air or static in the headphone. I also cue a song and its very loud and distorted, I turn down the gain on the skin and on the controller and same issue. I switch 4 headphones and cords and same issue. I am yet to try my Denon 8000, What can cause this and how do i fix it? Thank you
Posted Thu 22 Jun 17 @ 5:57 pm
Have you checked your audio settings ?
Both on VirtualDj and on your MAC ?
You should also avoid to use RMX2 sound interface for default MAC OS X playback.
Yes, I checked on software and never never had an issue w the RMX its rock solid and there is no settings that i know of with my mac. i checked on the rmx software and also on vdj where are the settings for this?
What is the easiest way to go back to the last build on a mac? what are the steps to do that?
I did that, I re started VDJ and it still says build 8.2 3780
One of my friends, so he got the personal treatment. It was a configuration error, so this is closed.
LOCKED BY AMAHM
EDIT:
Lesson 1. Do not update as you are about to start a gig.
Lesson 2. Save each build download, don't just run them. This way you know what your last build was that worked, so you can reinstall, if you ignore Lesson 1.
