Hi All
Since I buy music from so many different sources, one of my main problems has been getting equal or level volume without constantly adjusting the volume level control. I have that problem under control for mp3 files using the MP3gain program. Does anyone know of a similar program that will level flac files?
Thanks!
Thanks!
Posted Sat 20 May 17 @ 4:40 pm
A few seconds on Google finds Sound Normalizer by Kanz Software.
Of course if VDJ's auto gain doesn't work and adjusing a knob yourself is too much hard work, then you could always use audio editing software.
Posted Sat 20 May 17 @ 4:53 pm
Thank you..for some reason my search did not bring that up..I'll check it out.
Posted Sat 20 May 17 @ 5:05 pm
If you are happy with the results of mp3gain, you should just leave the VirtualDJ autogain setting to 'auto'
Since a couple of updates ago vdj uses the same replaygain algorithm to calculate the gain, so you will get the same results with your other file formats.
Posted Sat 20 May 17 @ 7:39 pm
