Topic: Master Volume
I have a VirtualDJ8 + Power Dynamics PDC-07 MIDI Controller + Bose soundtouch30 ;
VirtualDJ8 works on Windows10 and PC connected to Power Dynamics PDC-07 MIDI Controller with usb cable and Bose soundtouch 30 connected to the PC with bluetooth.
The problem is ; you can not control the master volume on the Power Dynamics PDC-07 MIDI Controller ,but all the other functions are operating well .
There is only one way to control master volume , it is on the bose application or it's remote control.
Any advice ?
Posted Thu 18 May 17 @ 6:48 pm
You can if you connect speakers to the master output of the PDC-07 - the way it's intended to be used.
Of course if your speakers are connected to the PC separately to the PDC-07 then the master volume knob on the PDC-07 will not control them.
Use a cable to connect the PDC-07 master output to the aux input of the Bose.
