Forum: VirtualDJ Skins
Topic: options .. experimental skin engine
is there any info or discussion on this anywhere please
Posted Tue 25 Apr 17 @ 8:54 pm
I don't think so (but maybe at a higher level - we can't see it).
Maybe it will be vector graphics?
Posted Tue 25 Apr 17 @ 9:04 pm
Vector graphics, or even resizable bitmap elements would be great..
Its kind of possible in the skin designer but if we could simply specify parts of the skin as bitmaps, like a play button and in the xml code it to percentage size...?
You could have all objects seperate and build them up in xml??
Maybe.
Posted Tue 25 Apr 17 @ 9:10 pm
Thanks Mr wickedmix, i did do a forum search but it gave nothing as you've spelt your topic on slightly differently, no worries matey.. got there in the end :)
Posted Wed 26 Apr 17 @ 12:10 am
my spelling sucks what can i say :-P
Posted Wed 26 Apr 17 @ 8:49 am
Unfortunately that thread doesn't tell us much either.
OK so the option is unavailable at the moment, but what will it do when it is available?
Posted Wed 26 Apr 17 @ 4:48 pm
You know how they are we have to wait and see :-(
Posted Wed 26 Apr 17 @ 5:03 pm
...but what will it do when it is available?
Come on, you know this: it's not permitted to say anything about things to come; even if somebody knows anything about this.
Stay tuned and drink a beer meanwhile.
Posted Wed 26 Apr 17 @ 5:53 pm
You don't need a crystal ball to know that skin drawing has been a resource and GPU hog since day one of 8 which should have never been.
Posted Wed 26 Apr 17 @ 7:49 pm
We know that one of DJ locodog skins do some funky new things that cause the skin to take longer to load on some systems, so perhaps it's a fix in that respect??
We could speculate all night but as we all know, we'll just have to wait and see :)
Posted Wed 26 Apr 17 @ 8:09 pm
