When I open my Broadcast page, I no longer see a place to enter a new stream. It looks nothing like the page I am used to seeing. I pretty much shows only a button for Broadcast. There is not place to enter stream or password. I can not seem to get it to broadcast anymore.
Posted Tue 21 Mar 17 @ 4:13 pm
In Settings>Broadcast tab do you have "Radio Server" selected?
http://www.virtualdj.com/manuals/virtualdj8/settings/broadcast.html
Posted Tue 21 Mar 17 @ 4:33 pm
No. I have selected Broadcast. I even downloaded VDJ8 and reinstalled it. I dept my files and playlist.
Posted Tue 21 Mar 17 @ 4:48 pm
You will need to check your settings in the Broadcast tab first. Make sure you have selected the Radio Server box (top middle) to see and/or change the details for your server.
Posted Tue 21 Mar 17 @ 6:38 pm
