Some files I have are getting stuck by VDJ when I try to recurse a folder with new content. It will say "46 Tags to read" so I know it's stuck on at least one. Then I start the process of removing files and re-adding them, restarting VDJ each time until I can find the file(s) VDJ is stuck on. One of the files is from a well known video pool. Has anyone found a solution to get VDJ to correctly read the file? Other than throwing it in a video editor and re-compressing the file all over again?
Posted Sat 18 Mar 17 @ 10:07 am
Could you send the file to me?
Posted Sat 18 Mar 17 @ 10:22 am
I have it on my other computer, but yes, I can send it to you. It's a vj loop on xtendamix.
I think I may have figured out what's going on. I think the files in question don't contain any audio. VDJ gets stuck reading the tags from the VJ loops and also from videos downloaded and saved from youtube that only contain video, but no audio. Like I said, it's on my other computer, but I can get those files to you if you would like.
Posted Mon 20 Mar 17 @ 4:52 am
Yes, one of those files would still be useful.
It's not stuck here when reading the tags of the files I have without audio.
Posted Mon 20 Mar 17 @ 7:16 am
