Topic: Problem with login - Page: 2
It's also been said many times - make sure your computer is logged in (i.e. the license file is present) before leaving for a gig. It should be if you haven't logged out.
Keep a backup of the license file. Most of the time if you're organised, you shouldn't need it, but if you do find yourself up the creek, it will come in useful.
Have a backup computer that's also got a license file (and a copy of it).
If you're a gigging DJ, don't rely on rented music. Buy it.
Posted Wed 01 Mar 17 @ 5:56 pm
bagpussPRO InfinityMember since 2003
PressNPlayDJ wrote :
Not really. He was just unlucky. He logged out, the day the servers had an issue. Like Adion said above, you never need to log out.
That's what I said, you should NEVER log out.
That said the software has become a bit touch and go since you now need to be logged in, user error or as in this case (if you have internet at your gig) you wouldn't likely consider the possibility of the servers being down the moment you need to login.
Posted Wed 01 Mar 17 @ 6:27 pm
Posted Sat 04 Mar 17 @ 1:31 pm
MemoveaPRO SubscriberMember since 2018
It’s not letting me login in when I’m loading up the software on my computer to connect my vms5 to start djing
Posted Tue 08 May 18 @ 9:27 am
Posted Tue 08 May 18 @ 10:16 am
the plug ins to fix the vd can not conect to the server shows as a virus can not use it another fix
Posted Thu 30 Aug 18 @ 6:29 pm
It's not a virus, your AV software just doesn't recognise it.
Switch off your AV temporarily then run it again.
Posted Thu 30 Aug 18 @ 6:36 pm
