Forum: VirtualDJ 8.2 Technical Support
Use this forum to report any bug, questions or comment related to the latest version of VirtualDJ 8.2.
Forum Guidelines
(NOTE: VirtualDJ 8.2 is continuously updated, so many older topic on this forum are most probably already fixed in the current build)
Topic: Komplete Audio 6 interface considered a "DJ Mixer" for home version?
Hi,
I'm a complete newbie and have searched the forums and inter webs for an answer but maybe I have got the terminology wrong.
I'm looking to play around with VDJ8 at home but my laptop speakers aren't great.
I have a Komplete Audio 6 audio interface that I was wanting to use to hook up to some speakers and was wondering whether this would be considered a "Dj Mixer" and thus I would be violating the home use policy OR it would cut out after 10 minutes if I used it?
If so, am I better off getting VDJ7 for now and trying it out for size...I'm assuming there would be no licence issue in this case?
Thank you for your help.
Posted Thu 12 Jan 17 @ 2:13 am
locodogPRO InfinityMember since 2013
Should be ok to use in a master & headphones set up, for auido quality I'd recommend v8 over v7 every day of the week.
Of course you'll need either powered speakers or an amp & speakers.
Posted Thu 12 Jan 17 @ 2:46 am
Thanks so much for your reply and top on VDJ8 over 7.
I assume the master + headphones will allow me to cue up on the headphones while the main output is going out of the speakers?
I have a Bose L1 system that I use as a solo acoustic musician.
Posted Thu 12 Jan 17 @ 8:26 am
That's right.
Posted Thu 12 Jan 17 @ 9:26 am
A german user "reported" the same.
He wants to use an Audio 2 soundcard and as soon as he tries to setup a master+headphone config VDJ asks for a "analog mixer licence".
Is this a new behaviour?
Posted Thu 12 Jan 17 @ 11:12 am
I'll check but I'm sure HLU's can use a AI as long as it's M&H
Posted Thu 12 Jan 17 @ 12:27 pm
I noticed recently the free version is hounding me every 10 minutes for a licence even though I don't have a multi-channel sound card.
Maybe just incorrect sound settings but bugging all the same.
Posted Thu 12 Jan 17 @ 12:29 pm
